PEUGEOT 306 EMERGENCY AID.
08.05.2020 18:36 # 1
ORHAN3437
SLM FRIENDS MY CAR IS MISSING OIL. I LOOK AT MOTOR OIL. ORHAN3437 2014-06-11 11:04:14
08.05.2020 18:36 # 2
Aziz
how did you understand this? when you get up from where you parked? can also be in gearbox oil
08.05.2020 18:36 # 3
ORHAN3437
I DIFFICULT THAT IT DROPPED TO THE WHERE I PARKED, LATER LASTED AND LOOKED AT THE DROPS.
08.05.2020 18:36 # 4
outlaw
WHAT DOES IT DROP OUT?
08.05.2020 18:36 # 5
Aziz
[QUOTE = outlaw] WHAT DOES IT DROP OUT?
+206
But it can glide from the leak and drip from different places.
08.05.2020 18:36 # 6
ORHAN3437
I DO NOT UNDERSTAND IN THE CARS, BUT THERE IS LIKE A WHEEL OF BACKGROUND THERE IS A WHEEL AND WHEN IT IS LIKE THE BIG BALL. THERE IS A LONG BELLOW IN THE FULL BACK.
08.05.2020 18:36 # 7
ORHAN3437
When I face the car, it stays to the left of the crankcase.
08.05.2020 18:36 # 8
Serkan
Transmission oil may leak from the axle seal.
08.05.2020 18:36 # 9
ORHAN3437
FOR YOUR COMMENTS, TSK.DEDI AS LIKE THE AXLE SEAL. LEFT BELLS
08.05.2020 18:36 # 10
kuscu38
Is there a liquid oil in the axle seal? Friends never met me Confused You may miss the oil from the axle seal, but the grease you know ... there is only one transmission oil that comes to my mind from where you call it ... just put the car in a shop that is idle with a scissors, rotbalancı or canal. .
08.05.2020 18:36 # 11
Serkan
[QUOTE = kuscu38] Is there a liquid oil in the axle seal? Friends never met me Confused You may miss the oil from the axle seal, but the grease you know ... there is only one transmission oil that comes to my mind from where you call it ... just put the car in a shop that is idle with a scissors, rotbalancı or canal. . [/ QUOTE]
Shouldn't you say axle bellows?
08.05.2020 18:36 # 12
ORHAN3437
IF FRIENDS HAVE BEEN MISSING FROM THE AXLE SEAL, WHICH I HAVE HEARED, THERE WAS A SIMPLE TRANSPARENT, WHICH WAS NOT SIMILAR TO THE ENGINE OIL.
08.05.2020 18:36 # 13
Aziz
It was obvious that it would be so, if there is no shortage in the engine :) this is a costly 50 TL. let's get past
08.05.2020 18:36 # 14
outlaw
THAT'S FUCKING AXLE FELT HAS HAPPENED TO ME AND I WERE AT THE SHOPPING MALL PARK ...
COMPLETE ALL TRANSMISSION OIL FLOWED ...
outlaw 2014-06-11 17:39:20
08.05.2020 18:36 # 15
outlaw
[QUOTE = ORHAN3437] IF FRIENDS ARE MISSING FROM THE AXLE SEAL, I HAVE BEEN MORE OPEN TRANSPARENT TRANSPARENT ENGINE OIL. [/ QUOTE]
YELLOW IS MORE LIQUID FLUID ...
08.05.2020 18:36 # 16
kuscu38
[QUOTE = Serkan] [QUOTE = kuscu38] Is there a liquid oil in the axle seal? Friends never met me Confused You may miss the oil from the axle seal, but the grease you know ... there is only one transmission oil that comes to my mind from where you call it ... just put the car in a shop that is idle with a scissors, rotbalancı or canal. . [/ QUOTE]
just as I mentioned the axle bellows
08.05.2020 18:36 # 17
popeyes
[QUOTE = ORHAN3437] SLM FRIENDS MY VEHICLE IS LOADING OIL. [/ QUOTE]
transmission oil is missing my brother is a simple operation to look at.
