Peugeot 306 brake system maintenance
08.05.2020 20:32 # 1
x571
Hello
Vehicle 2002 306 sw1.6 petrol
After a while, the brakes will go into maintenance. The last 50,000 km of brake maintenance.
The rear brake center has changed. The repair team has changed. The Balat has changed the discs have changed, the brake oil has changed.
The vehicle is now at 118,000. Which parts may be tired and which should be changed.
I looked at the sponsor of the forum, I could not find the pads and discs. I looked at the previous sponsor there, but it does not write the original. Where can I supply the original.
Now can I brake the disc to the backs of the brake pads in 1.8 and 2.0?
08.05.2020 20:32 # 2
[QUOTE = x571] Hello
My teacher backs don't get into the disc brake business, it seems like a simple process. If you want the original, I think you should not call too much, you can also use the products of oem manufacturers such as trw-valeo-brembo and these products are really quality products.
08.05.2020 20:32 # 3
x571
[QUOTE = sonerkyl] [QUOTE = x571] Hello
elsewhere , the Westinghouse, main center, caliper pin and piston seal lose their function over time. Is it necessary to change them over time
08.05.2020 20:32 # 4
Honestly, if you enter them, you will have a lot of money.
