PEUGEOT 306 2001 ENGINE MOUNTING PROBLEM
08.05.2020 19:04 # 1
oguzhan04
MY VEHICLE 306 - 2001: HOW MUCH DAY WITH GASOLINE DOES A KICK ON 3 AND 4 GEARS WITH RAMP UP UP. THE MOTOR ERROR IS ON THE INDICATOR. EVERY PARTY OF THE CAR IS FLATING; GAS DOES NOT EAT AND MAKES A VERY STRANGE SOUND. WHAT SHOULD I HAVE TO FAIL, WHAT TO DO, I WOULD BE SATISFIED IF YOU ANSWER. GREETINGS. oguzhan04 2015-02-05 13:13:16
08.05.2020 19:04 # 2
sivas_-5858
h;
306 sedan 99 models 16
singing on gasoline lpg problem also helps?
08.05.2020 19:04 # 3
T€K€
While the car is running, take off the spark plug wires from the side close to the spark plug. Then, close the metal parts of the engine until it is 1cm. If it still does not jump or if there is a weak jump compared to others, you can change the coil directly.
