peugeot 306 1.8 Lpg more fuel
08.05.2020 17:59 # 1
erman306
Good luck in my Peugeot 306 1.8 1996 model car, lpg too much fuel, even a little fuel coil spark plugs lpg brain (ecu) lpg sensors have all changed but I still do not understand why it burns so much I made 30 km fln for 20 tl gas can you help please
08.05.2020 17:59 # 2
erman306
Friends with information please help :(
08.05.2020 17:59 # 3
gogly35
I think the situation is pretty bad, could it be illegal?
08.05.2020 17:59 # 4
erman306
lpg setting did it all lpgci is not familiar stranger (ecu) yu changed the brain without changing the brain, the engine was running jerky everything was fine but it was burning very well I said it does not burn now lpg ci but i am still going to eat the yakyo I also want to reply
08.05.2020 17:59 # 5
Serkan
How are you doing the consumption test, sir?
08.05.2020 17:59 # 6
gogly35
For 20 lira I am making 75-80 km in the city .. if you want, you can consult other places, where are you in Izmir?
08.05.2020 17:59 # 7
erman306
I was not using my car in LPG, I bought gas from 20 TL gas, then I reset the km, went, I came home, I finished the gas, the lamp was flashing, maybe even more burned: D I clean everything in the car, I love it very much, I hope my car has ruined me, I really got cold :( let me clean everything of the car, the tube head, the butterfly throat, the dislocation of this place, let's clean it, I hope that it will improve like this :( and how can we understand if there is a leak?
08.05.2020 17:59 # 8
erman306
There are 2 places in Izmir Gaziemir. LPG service is in Çınarlı Bornova alsancak, but they are all the same either: (I said to the man (ECU) if the brain is faulty, let's change it. I said it was okay. If I did not say it, they would send it to the mechanic: :D
08.05.2020 17:59 # 9
Serkan
Sir, if the LPG pressure is low, the gas in the tank can switch to gas before it runs out.
08.05.2020 17:59 # 10
erman306
I understand, Serkan Bey, I will go on the long road on the eve of the road, it will burn 140 km, but it can burn again, so I will be very comfortable if I solve this problem :( Thank you very much. I just plugged it in, so its settings may have been deleted?
08.05.2020 17:59 # 11
Serkan
The setting is not reset by disassembling the pole, as I said, when the LPG pressure is low, sometimes the vehicle will switch to gasoline even if there is LPG in the tank and we think that LPG is over. Hopefully a good result will come from the test.
08.05.2020 17:59 # 12
erman306
I hope the problem is with him, but he shouldn't have burned it too much or switched to gasoline immediately. 2 lights were on. I made 15 km.
08.05.2020 17:59 # 13
Fourhan
brother I have the same problem right now ya I can go to 30 pounds 35 kilometers but I can go to LPG
08.05.2020 17:59 # 14
Fourhan
brother did you solve the problem now the same is happening to me
08.05.2020 17:59 # 15
the main reason for this is lpg settings and injectors
