Peugeot 301 Gives Error Code P1166
08.05.2020 21:08 # 1
VR38DETT
The tool was made with software + downpipe and gave this error code when I compress it after 2-3. I would be glad if you can illuminate it thanks
08.05.2020 21:08 # 2
27BEN80
my brother got a quote from a source probably as a warning about fuel .... Error code P1166 After the sales definition of the fault code High pressure fuel regulation: Rail pressure measured higher than maximum pressure Correction priority 3 Diagnosis definition Diagnostic pressure higher than maximum pressure: 5 seconds Throughout the 1750 bar Diagnostics activation conditions For Pcode transmission conditions, see relevant contents. Conditions for the elimination of the fault 5 minutes driving Sub-stepped modes if there is a fault Switching off the engine Irreversible disconnection of the cruise control Disabling automatic mode for the electronic parking brake Disabling the speed limiter Disabling the warning light and / or warning message Lamp MIL Symptoms (Possible customer complaints) Power Lack of Jerking / Suspected areas Lack of electrical wiring Connectors High pressure pump Engine ECU Diesel fuel high pressure sensor
08.05.2020 21:08 # 3
VR38DETT
I am considering removing and cleaning the fuel pressure sensor. Thanks in the meantime
08.05.2020 21:08 # 4
27BEN80
I hope the problem is solved
02.03.2021 19:26 # 5
MOAT
salamlar,
I also had the same problem with my 1.4 HDi vehicle. I have only stage1 software. Is the problem solved by cleaning the pressure sensor?
01.06.2021 23:52 # 6
Stilem
I'm getting the same fault code, how did you fix it?
01.06.2021 23:52 # 7
Stilem
Hello, how did you solve the problem?
