Peugeot 3008 start-stop and battery light
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 20:53 # 1
bulentkoroglutr
Hello Friends,
First of all, I have a 2015 model Peugeot 3008 allure in its nose. I don't think the reason for buying the car is high and its fuel is economical (my old car VW Passat 1.4TSI)
I would be glad if you answer a few questions.
1. I started the car in the car park, I saw a very strong ringing of gold, and I think that the electronic parking brake wire was quickly released.
On the first morning of my 2nd purchase, I ran it quickly, gave "Engine Failure" and then wrote "Have the engine repaired". I switched off the ignition, switched it on again, it didn't malfunction, or no lights were on.
3. When I started in the morning, Start Stop was working, but when I returned home in the evening, I noticed that the start-stop was not working and when I applied the brake, the ECO light flashes a few times. Can the battery be problematic or Can the battery charge circuit be problematic? If there was a malfunction, the light would be on the screen.
Sorry if I opened the issue in the wrong place.
Thank you so much in advance for your answers.
08.05.2020 20:53 # 2
Selcuk55
I do not think that there is a hand brake before the indicator lights disappear. There is a different thing in the cinema there is different if the battery is weak, if the air conditioner is on, the start window will not start if the rear window heating is on, but the engine may not enter when cold, but the first battery and dynamon are checked.
08.05.2020 20:53 # 3
ozgurdogrul
Never start without stopping the lights ... Many factors are required for start & stop, but have your battery charged, if the battery is weak, the vehicle may give strange warnings ... (engine failure, hand brake failure, ignition system failure, tire pressure failure ..... .) If your vehicle is frequently used at short distances, the battery is not sufficiently charged ... do not think about battery replacement right away ... If your vehicle is charging after 80-90 km of long road use and if there are similar warnings, the battery change has come during the first start in the morning. ..I had the same problem in my previous 2010 and 2013 model 3008s and both of them changed the battery after a certain period of time ...
There was no star stop in the 2010 model and 1 week after the engine failure, automatic handbrake failure warnings started to appear, I loaded the car in the first day I stayed on the day of the summer vacation, the battery changed (standard battery).
Since I was experienced in the 2013 model, start stop was not activated and malfunction warnings started, I immediately measured the battery, while it was fully charged, it turned out 54%, and I changed the battery, the only difference is the start stop batteries (70 amp 760mh AMG (gel) Battery) at twice the standard batteries (currently 700- 800TL)
08.05.2020 20:53 # 4
ilter81
Hello, I had the same problem today. I started the car gave engine failure and start stop became passive. Already for 6 months start stop was not activated even though I was hungry. I asked the service they said that the battery is weak. Did you solve the problem when the battery replaced the problem? The fault warning is gone. thanks
08.05.2020 20:53 # 5
bulentkoroglutr
Hello,
I changed the battery. Start & Stop started working a few hours after the battery changed.
it looks the same in your problem.
If you are in Istanbul, you can get it economically from http://apaydinlaroto.com/ .
You will get 72A Varta AGM battery.
Best regards.
08.05.2020 20:53 # 6
[QUOTE = ilter81] hello I had the same problem today. I started the car gave engine failure and start stop became passive. Already for 6 months start stop was not activated even though I was hungry. I asked the service they said that the battery is weak. Did you solve the problem when the battery replaced the problem? The fault warning is gone. thanks
exactly, my teacher is from the battery. As the bulletin brain says, if you change your battery, your problem will disappear.
08.05.2020 20:53 # 7
ilter81
thanks
08.05.2020 20:53 # 8
samet2461
Don't ignore it. If the belt is always fastened, after a while the vehicle detects this and start stop is disabled. If the buckle that is attached to trick the side warning system or the belt passed behind the seat is not removed at all, start stop does not work after a while. System that is adjusted to remove the belt while riding and getting off. Wink
samet2461 2018-12-18 01:13:44
10.03.2021 21:33 # 9
Dsl
Hello friends,
I am a user of 2013 model 3008 2 days ago, I changed the battery, a fault light sometimes lights up, sometimes it does not light at all, the gear box is malfunctioning on the alarm panel. The reason is that the malfunction exclamation mark is on the panel.
