Peugeot 3008 parking brake control malfunction
19.02.2022 13:36 # 1
Hamdullah
Peugeot 3008 On my 1.6 BlueHDI Feline 2015 model vehicle, the parking brake control failure warning is occasionally displayed. If there is no sound from the parking brake when I touch the parking brake button when I start it for the first time, I immediately understand that the brake control will malfunction. It is a problem that I have from time to time while parking the car on the way home. In the past, this warning error would sometimes occur from time to time. It gives more frequent warnings now. But sometimes it works normally. It doesn't matter if the engine or the car is hot or cold.
This I am waiting for a reply from friends who have suggestions and who are experiencing the problem. Is there anything I can do? I am waiting for a suggestion for a center in Ankara where I can find the most appropriate solution.
19.02.2022 15:14 # 2
GokhaN
It's not something you can do, take it to the authorized service and have it checked. If they cost a lot, if you start looking for a private service, they should identify the problem first.
19.02.2022 17:48 # 3
Hamdullah
Even though I am an electrical graduate from ODTU, of course, I also know that there is nothing I can do. The purpose of my asking if there is anything I can do, I was asking if someone who has experienced this kind of problem can suggest the right master or repairman. When a person has a physical ailment (heart, stomach, kidney, etc.), there are many doctors and many hospitals, even among specialist doctors, there are certain doctors that he can recommend.
I went to Peugeot Göral's regular service for years. Göral cost me a lot in my previous AdBlue problem. When I said let it be with me then, although they did not take any action, they incurred a cost called the detection fee. The problems I experienced in services, especially Göral, caused me to worry about trust and indifference towards the services. (eg charcoal exhausted charge It doesn't make sense to completely replace the dynamo.)
You have a problem no matter what brand of vehicle you have If there is a suggestion "you should go to the service" is something that ordinary people can say to solve the problem.
Peugeot service as someone who has suffered from a similar problem, that is to say the one who fell off the roof I needed your advice and suggestions. As every problem has a chronically problematic part, it has honest masters who do their job properly. The right master, the right piece, the real solution, not inflated.
19.02.2022 18:23 # 4
GokhaN
I thought and wrote that your vehicle is new, don't creep, it's in the industries. I understand your psychology, since you are a METU graduate, you are trying to enter and continue with the limit.
20.02.2022 01:04 # 5
Hamdullah
"Sizin yapacağınız bir şey değil yetkili servise götürüp baktırın. "
cevabınıza istinaden böyle bir açıklamaya ihtiyaç duymuştum. Nitekim kendi birikim ve tecrübem dahilinde daha önceki arabalar ve bu şu an kullandığım araba için risk alabildiğim ölçüde müdahalem olmuştur.
Bu müdahalelerimde sorunumu paylaştığım platformlarda aynı sorunu yaşamış ve hangi doğru metotla çözüme ulaşmışların kılavuzluğundan çok istifade ettiğim olmuştur.
Benim de bildiğim bir konu olduğunda, faydalı olduğum arkadaşlar olmuştur.
Bilgi paylaşıldığında faydalı olur. Kimseye bir faydası yoksa, kişiye yüktür.
21.02.2022 10:32 # 6
Well, what does it give as a fault code? In old cases, this problem was caused by the fuse box in the engine compartment.
