Peugeot 3008 air conditioning inconsistency problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
01.08.2023 18:00 # 1
ibanezjs1200
Greetings. I have a 2015 Peugeot 3008 1.6 BlueHDi EAT6 with 140,000 kilometers on it. Last year, on my way back from Antalya to Istanbul, my air conditioning stopped working during the trip. The problem resolved itself after I arrived in Istanbul. Later, because the weather got cooler, I only had it checked this summer. This summer, the air conditioning was cooling in Istanbul, but before going to Antalya, I took it to an air conditioning repair shop to avoid any problems. The air conditioning repair guy immediately refilled the gas. However, when we got to Antalya, we had problems. Sometimes the air conditioning cools very well. Sometimes it doesn't. I can't figure out why it's cooling or not. For example, I set the car's air conditioning to 22 degrees Celsius. I set it to automatic fan. Even though it's 40 degrees outside, it cools very well. Sometimes it's 40 degrees outside again, but even if I set the air conditioning to the coldest setting and the fan to the highest setting, it still can't cool. Sometimes it's 28 degrees outside, but it still doesn't cool enough. But sometimes it cools so much that I have to turn the air conditioner down to 23 degrees. As I said, I can't figure out what determines whether it's cooling properly. My car is currently in Istanbul. Who can do a detailed check on this for a Peugeot? Can the condenser and evaporator be cleaned? Where can I get it done? Could there be a problem with the vehicle's interior temperature sensor or exterior temperature sensors? Could there be a problem with the moisture-absorbing filter? Does it make more sense to have the gas refilled at an authorized service center? Performance also varies depending on the quality of the gas used. ibanezjs12002023-08-01 18:01:22
