PEUGEOT 208 HILL START ASSIST
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
19.04.2022 14:14 # 1
serkrc
Good day everyone, good forum.
I bought a 2013 model 208 1.2 VTİ Active semi-automatic vehicle. These vehicles have hill start assist, I know. This boost in my vehicle is not working properly. There is a forward hold on uphill movements, but it's not like you're pressing the brakes. It should brake fully for 2-3 seconds and start, but it doesn't. There is no reverse movement. I'm wondering where can this problem come from?
In the user manual it says that the driver's door should be closed. When I first bought the vehicle, the brain of the vehicle did not see that the door was closed. I fixed this problem. There has been a disconnection in the sockets going to the door, the door is working properly. Hill start assist improved after this treatment, but it doesn't seem to be working properly. Could it be a problem with the brake system?
I would appreciate if you share your thoughts on this subject. I need to solve this problem because it is very difficult to hold the vehicle on a slope.
Thank you in advance. Have a healthy day.
20.04.2022 09:33 # 2
Hello, I think there is no problem, sir, I used it at that time, there is a very light grip on semi-automatic Peugeots. If you still want to be confused, change the brake hydraulic oil and have the pads checked.
20.04.2022 09:39 # 3
serkrc
Hello.
Thank you.
The pads are in good condition, but I'm thinking of changing the brake fluid. Let's not have a malfunction electronically, it is very difficult to find. If anyone has experience on this subject, I would appreciate it if they could write.
20.04.2022 10:09 # 4
You will not have any problems, sir, it is easy to change. master does. When your vehicle's oil service comes, you can change it together.
23.04.2022 00:10 # 5
ZylmZ
Hello friends, I joined you with a 2008 model semi-automatic 207 premium. I have never used a semi-automatic or automatic vehicle before and it is my first Peugeot brand vehicle. I just bought the vehicle. During the inspection, I saw oil in the transmission area. The ministers said it was not important, but I will show the vehicle to a transmission master tomorrow. .What I want to know is if the transmission oil level is not sufficient to add or change, what is the brand code of the transmission oil of this vehicle? I am looking for help from friends who have changed or added before or have knowledge about the subject. There is slight shaking in position and more intense shaking in R position. Thank you in advance.
23.04.2022 12:47 # 6
ZylmZ
Hello friends. I need information about the transmission oil for the 2008 model semi-automatic 207 premium. They said mobile in most places. I just called an authorized service. He said Total. But he did not tell the code. He also said that it does not matter semi-automatic or automatic. There is no service in Karabukte. I would appreciate it, it's a bit urgent. Thank you in advance.Embarrassed
