Peugeot 208 engine preheating problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 18:27 # 1
mirza72
My vehicle is a 2012 model diesel vehicle. Continuous malfunction light is on. When I connect it to the computer, the p1352 engine is malfunctioning. In his description, he says a territorial fault. He says there may be a malfunction in the glow plug or roller. I got the spark plugs checked first, 2 spark plugs changed. We deleted the malfunction code and burned it again 2 days later. We looked again after the same breakdown, we changed the role. After 2 days, he again gave the same fault. We cannot find out what the problem is now. What do you think we should do?
08.05.2020 18:27 # 2
mirza72
I would appreciate if you help. No one to help?
08.05.2020 18:27 # 3
alman10
Has the installation between the relay and the spark plugs been checked? not all faults may be caused by parts.
08.05.2020 18:27 # 4
ahmed206
[QUOTE = alman10] Check the installation between the relay and the spark plugs? not every malfunction may be caused by parts. [/ QUOTE] +1 Ermm
