peugeot 208 1.6 Vti engine error
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
02.05.2022 23:11 # 1
ahmetbaris06
Friends, first of all, hello alaikum. In my 1.6 Vti 2012 vehicle, I have been getting the engine error, have the vehicle repaired, two times. Previously, after I didn't downshift while I was driving with the vehicle, I had a vibration in the engine and a traction problem when I manually downshifted, then the fan runs non-stop, I pull the vehicle to the side and stop, the fan still continues to run. When I start the vehicle again, I don't have any problems with gear shifts in engine traction, but the fault lamp does not go out and the fan continues to run continuously. I stop and wait for 10 minutes, the fan turns off. I was wondering if anyone had a problem without putting it in the machine, I would be very happy if you could help. If you have a suggestion for a master who understands the Peugeot 208 well in Ankara, I can take your humble suggestion. Thank you from now
06.05.2022 08:46 # 2
Hello sir, the problem seems to be probably caused by the solenoid valves or the spark plugs. Connecting it to the device is the best guarantee. If you are looking for a good master in vti and thp
SF Auto Garage serdal master ivedik
02.05.2023 04:31 # 3
MehMetC3
What is the problem? You had it done a long time ago. When I look at the history, it was the problem.
