Peugeot 208 1.2 oil reduction problem.
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
07.03.2022 10:41 # 1
grafikeh
Hello, my vehicle is Peugeout 208 1.2 82HP access 2015 model.
I normally need to have my vehicle oiled at 15,000 km.
But I noticed that there is a lot of oil reduction without 10,000 km.
Maintenance km sini I had to pull it forward.
Then I would investigate that my car might be burning oil.
There are many ways to detect this. Bwn I won't talk about them
I heard something new, my car's oil is 0W30 Total, this oil performance
It is put in cars or starter models that are good.
After 100k, the oil thickness will increase had to increase.
The engine can now cause oil burning or leakage.
Is there such a thing? If yes, what should I use instead of 0W30?
07.03.2022 11:39 # 2
Hello teacher. There is no need for such a situation in the case of engine oil thickening after 100 thousand, new generation engines originating from our masters in our country. I still put factory oil 5w40 in my 280000 km vehicle, no matter what anyone says. One of the biggest reasons why many companies use 0w/30 oil in their vehicles after 2015 is carbon emissions in EU conditions. I prefer not to change it, I suggest you to continue by adding..
09.03.2022 00:05 # 3
grafikeh
Understood. Thank you very much for your suggestions.
16.04.2022 20:35 # 4
Puger208
Greetings, teacher. What is the make, model and year of your vehicle? I'm a 1.2 vti 2012 user too. There is 300-500 ml of oil reduction at 5000 km, but the masters always put 5w30. Recently, special Bi pejo service said that 1.2 vti's factory recommendation should be 5w40. Now there is a mobil esp 2 5w30 in the vehicle and it says thinner than normal in oil. Does using 5w40 reduce fat burning? My car is at 94 thousand km and do you have such a problem?
18.04.2022 09:25 # 5
Do not add any oil other than the oil viscosity specified in the booklet, and do not mind the masters. I don't have a teacher, it's thin, etc. Then we say why the engine broke down, the biggest reason is still old information. In new generation vehicles, thick oil will shorten the wear time in the engine. There is a certain amount of oil reduction in many new generation gasoline vehicles and it is a must-have. After all, it is a substance that heats up, cools and evaporates in the meantime.
