Peugeot 207 Sudden Temperature Rise
08.05.2020 20:26 # 1
SedatDK
My vehicle is peugeot 207 2008 Model Gasoline. When the temperature of my vehicle is gone a little, especially when the speed exceeds 90 km, the temperature rises suddenly and it gradually decreases when the gear shifts to the blank or the fan turns on. It rises fast and falls fast. The thermostat knuckle timing belt has changed but the fault continues. The heat rises to the top and falls back until it draws to the right. What is the problem? I always say different things to whomever I take it. If there is a good master you know in Çorlu, I am also open to suggestions.
08.05.2020 20:26 # 2
maximusti
temperature is normal around 90 100. peugeot likes to work hot.
when you stop and get up to 100 110,
The important thing is that whenever he says 110, he should turn on the fan. If the fan is turning on, no problem.
When I come to the soup, Istanbul outlet is 100 110, and after silivri it drops to 80 90 each time.
08.05.2020 20:26 # 3
SedatDK
Generally, the temperature is already 105 and 110. The fan is running. If a little speed is made, it goes up to the top and sometimes even warns to stop.
08.05.2020 20:26 # 4
SedatDK
When I say speed is 100-110. Thermostat timing switch has been changed. We look at the pipes, they are hot.
08.05.2020 20:26 # 5
talip206
If the temperature rises as the speed increases, the problem is definitely the circulation engine. Do not look for the problem elsewhere.
08.05.2020 20:26 # 6
SedatDK
The heat in the city is always at 110 da. When the speed increases to 100 km or when the vehicle gets a little harder, it shifts back to 110 and 105 in front of the fans. In this heat problem, I have never done excessive speed with the vehicle once. The temperature gauge comes out and falls fast
08.05.2020 20:26 # 7
OguzhanKucuk61
This high temperature is not normal, at a constant speed of 100-110 km. When the air conditioner is turned on in the city, it comes to mine
08.05.2020 20:26 # 8
SedatDK
Yes, it is not normal, what could be the problem?
08.05.2020 20:26 # 9
OguzhanKucuk61
Is there an antifreeze in the vehicle. Does water decrease? does the fan turn on? Maybe the 2nd Degree fan does not turn on?
08.05.2020 20:26 # 10
SedatDK
Since the temperature of the car is too high, there is a decrease in water. But this water reduction does not always happen. The 2nd degree fan opens at 110 or so
08.05.2020 20:26 # 11
OguzhanKucuk61
Is there a situation such as fluctuation stop at idling speed? Or like opening a timeless fan?
08.05.2020 20:26 # 12
SedatDK
The big fan hurts at 95. I did not understand the incident called idling because I did not know the car technical features very much.
08.05.2020 20:26 # 13
OguzhanKucuk61
[QUOTE = SedatDK] Big fan is open at 95. I did not understand what it was called idling because I did not know the car technical features very much [/ QUOTE]
when the car is not running, i.e. idling. Does the tachometer needle move or is it fixed? If there is a play, the temperature sensor may be defective. it may be linked to your issue.
08.05.2020 20:26 # 14
SedatDK
It stands at 1 fixed, but again I look carefully
08.05.2020 20:26 # 15
talip206
I am rewriting, it is definitely related to the circulation when the speed increases. The circulation cannot fulfill its duty. Did the recirculation engine change as the timing changed? If it is changed, is it a subsidiary industry
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
