peugeot 207 steering wheel hardening
08.05.2020 18:43 # 1
dadyy
pejo 207 1.4 I have a diesel car, the steering wheel hardened suddenly, I took it to the authorized service. The steering module on the steering box said that the steering module was defective. A charge of around 1250 TL was asked in 3 weeks.
08.05.2020 18:43 # 2
Efe-Pojo
I also felt some hardening, which could suddenly cause the steering wheel today? Is there an oily system in vehicles with electro power steering? I wonder if the oil has decreased?
08.05.2020 18:43 # 3
GokhaN
it will be 1 year since the message is written, it is almost late for the reply Smile
08.05.2020 18:43 # 4
Efe-Pojo
[QUOTE = GökhaN] it will be 1 year since the message is written, it is almost late for the answer Smile [/ QUOTE]
No, I didn't write it as an answer, I wrote it as a problem. new topic should not be opened for each problem and should be searched and found in the forum I wrote here because it was just mentioned by the forum, but no one can notice the look at the master section.
08.05.2020 18:43 # 5
Efe-Pojo
If anyone thinks, the hardness I mentioned is not a problem, as far as I understand; Steering automatically hardens on wet or icy ground, softening on dry asphalt. I tried it 2 or 3 times before writing ... it seemed to me like that .... after all, I commented that it is normal, the pressure on the steering column decreases and hardens as the speed increases, the same is valid when the rotation response decreases where it stops, the brain condition is noticed and hardens itself.
