Peugeot 207 sound system recommendation
23.07.2020 15:49 # 1
bloodrap
Hello friends, I have a 2012 model Peugeot 207. The sound system is only available at the front doors. tape etc. all original. The current sound system is not enough for me. In addition, I want to install it in the back doors. What should I buy, what would you recommend? I have no information on this subject:) If the bass balance of the speakers I will buy is also good, it would be very good. Is it okay if I put it on the front and rear doors when I buy 2 of them and make an original tape connection? Is this possible? https: //www.hepsiburada.com/jbl-cs760c-16-cm-150-w-mid-oto-hoparlor-p-HBV00000BGNO4
24.07.2020 14:03 # 2
First of all, welcome to us. You can not get much efficiency without a companent amp, sir, even if you change the tape. JBL Peugeot has original speakers. If you say the parts are rcz model, you can find them in spare parts. can be both in the original socket.
27.07.2020 08:39 # 3
yldrmcbb
[QUOTE = sonerkyl] first of all welcome to us. You can not get much efficiency without a companent amp, sir, even if you change the tape. JBL Peugeot has original speakers. If you say the parts are rcz model, you can find them in spare parts. both can be in the original socket. [/ QUOTE] Soner Bey, which is the best speaker you can recommend for rd4 tapes? Will the RCZ model speaker be compatible?
27.07.2020 10:42 # 4
okay teacher, it will not be a problem. speaker diameters are the same because
04.08.2020 08:54 # 5
bloodrap
[QUOTE = sonerkyl] first of all welcome to us. You can not get much efficiency without a companent amp, sir, even if you change the tape. JBL Peugeot has original speakers. If you say the parts are rcz model, you can find them in spare parts. both can be in the original socket. [/ QUOTE] I liked it, thank you. Can you tell me directly that you need to buy these? rcz model what is the original socket i don't know :)
