Peugeot 207 semi-automatic transmission problem.
10.12.2025 20:27 # 1
Burhan38
My car is a Peugeot 207 semi-automatic gasoline model, and I live in Kayseri. Let me briefly describe the problem with my car. The car itself doesn't have any operational issues. The engine starts, but when I press the gas pedal while the car is in neutral, the throttle response is normal. However, when I shift into forward or reverse, the throttle response is zero, and the triangular fault light comes on. Removing and reinserting the ignition key a few times resolves the fault, and the car starts normally, but it shakes slightly after 5 or 6 meters, and gear changes normalize. However, sometimes the car won't move in gear while waiting at a traffic light. Again, removing and reinserting the ignition key a few times solves this problem, but it causes problems for both traffic and myself. When I took it to a mechanic, they diagnosed fault codes P1702 and P0750. They said the transmission robot needed replacing, which I did, but the problem persisted. Then they replaced the battery, but that didn't solve the problem either. The transmission wiring was checked, but that didn't work. The transmission control unit software was checked, and the clutch was replaced, but the problem still continues. I've been experiencing this problem with my car for about a month now, and I'm waiting for your help. I would be very grateful if you could assist me. I will.https://static.cloudflareinsights.com/beacon.min.js/vcd15cbe7772f49c399c6a5babf22c1241717689176015" integrity="sha512-ZpsOmlRQV6y907TI0dKBHq9Md29nnaEIPlkf84rnaERnq6zvWvPUqr2ft8M1aS28oN72PdrCzSjY4U6VaAw1EQ==" data-cf-beacon="{"version":"2024.11.0","token":"11ac6a036a5c4b83a3c20a30a3bc3ba2","r":1,"server_timing":{"name":{"cfCache Status":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">
15.03.2026 14:14 # 2
Semih19
I had the same problems; I changed the clutch, it didn't work; I changed the battery, it didn't work; finally, I changed the transmission housing and now there are no problems. What's the latest situation with you? data-cf-beacon="{"version":"2024.11.0","token":"11ac6a036a5c4b83a3c20a30a3bc3ba2","r":1,"server_timing":{"name":{"cfCache Status":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">
15.03.2026 15:19 # 3
Burhan38
The problem was with the Aksiyoner; we wasted a fortune. There are no more problems. https://static.cloudflareinsights.com/beacon.min.js/v8c78df7c7c0f484497ecbca7046644da1771523124516" integrity="sha512-8DS7rgIrAmghBFwoOTujcf6D9rXvH8xm8JQ1Ja01h9QX8EzXldiszufYa4IFfKdLUKTTrnSFXLDkUEOTrZQ8Qg==" data-cf-beacon="{"version":"2024.11.0","token":"11ac6a036a5c4b83a3c20a30a3bc3ba2","r":1,"server_timing":{"name":{"cfCache Status":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">
