Peugeot 207 Problem
03.04.2021 08:43 # 1
hunkarus
Selemun Aleyküm friends
my vehicle is 207 (2019)
My problem is as seen in the picture
I guess I drove the car for half an hour but normally it has a thermostat problem. It should have been 90 degrees, but it has never happened. The gasoline gauge has strayed.
03.04.2021 08:50 # 2
hunkarus
https://resimyukle.xyz/i/IG7WeN
03.04.2021 12:31 # 3
berate38
I also have the same problem. I changed the complete thermostat with the heat sensor. It passed and it happened to me again.
03.04.2021 12:52 # 4
hunkarus
thanks well, will you handle me like this for a day or two
03.04.2021 16:07 # 5
berate38
The engine temperature sensor on the thermostat was malfunctioning, under normal conditions, the temperature is 90, but the pointer shows incorrectly, it will not be a problem.
29.06.2021 17:07 # 6
antipollution
Guys, is there a chance that this temperature sensor will show 10 degrees lower? My car is overheating but the indicator is always in the 90s
29.06.2021 17:33 # 7
GokhaN
our engines are running at high temperatures 90 degrees is normal, it was on my 3008 and previous peugeots. If it's cool on the long road, the air drops to around 85, that's it.
