Peugeot 207 mit team or component team recommendation
08.05.2020 20:37 # 1
can0753
I have a Peugeot 207 2007 MODEL vehicle, this vehicle has;
Bass: Kicker ES 1200w
Bass Amplifier: Hacker DX-300.2
Would you recommend 1 myth kit or component kit that the amplifier will lift instead of the front speakers of the vehicle Pioneer power GM-X402 of the vehicle's own speakers ?
They suggested the Component team in the link I gave below in another forum. Is there any component set or myth set that you would suggest instead?
Thanks in advance.
- Recommended Component kit Link: http://www.hepsiburada.com/soundmagus-sm-17c-16-cm-component-takimi-p-OTAKTSM17C?magaza=Hepsiburada&wt_gl=cpc.tum.genel-mobil.pla&gclid= eaıaıqobchmıpdzam5gk1wıvrrztch3bsalzeaqyasabegljwfd_bw to
Look at my fucking link: https://urun.n11.com/hoparlor/mit-takimi-16cm-200w-midrange-component-jameson-jmd-1616-p192363260?cid=604001&gclid=cj0kcqjwm9vpbrcqarısabaıqyecxjx7ulbbd33joadmufzlz291zjyaj3jyuo-qwndguhitslmdrqwaancgealw_wcb&gclsrc=aw.ds
08.05.2020 20:37 # 2
onlycihan
soundmagus better quality for me. Wouldn't it be higher quality if something more familiar is in jbl style?
08.05.2020 20:37 # 3
can0753
So does this JBL CS760C 16CM MIDI SET give better quality and louder than that , so is it worth buying instead of the Soundmagus Sm17C Component Kit?
Will my front doors have a problem with the installation of 16 CM, and importantly, does the anfim lift? It will be as follows, if I take your suggestion, my system;
1 set JBL CS760C 16CM MID SET replace front speaker
Does this remove the amplifier with the car's original rear speakers and the original tweets in the front?
Pıoneer power GM-X402
The main unit has 2 way tape.
can0753 2017-10-30 17:50:45
08.05.2020 20:37 # 4
can0753
[QUOTE = onlycihan] soundmagus better quality for me. Wouldn't it be higher quality if something more familiar is in jbl style? [/ QUOTE]
08.05.2020 20:37 # 5
can0753
So does this JBL CS760C 16CM MIDI SET give better quality and louder than that, so is it worth buying instead of the Soundmagus Sm17C Component Kit?
Does the car remove this amplifier with its original rear speakers and the original tweets in the front?
08.05.2020 20:37 # 6
onlycihan
I personally worn the coax of the four-door speakers again. There is a head of the amphitheater alpine in the back, folks complain about me. If we come to you, the system looks good, you can separate the 2 outputs of your 4 channel amp to the mid bass set on the front doors by bridging the other 2 channels. You can also connect the rear speakers of the original to the tape output, but not as much as the front, but there is no sound, but a good sound can be obtained with a clean setting.
08.05.2020 20:37 # 7
maximusti
I couldn't find the old model power values of the amp, but I would say my personal opinion;
I do not recommend brands such as Jameson, Goldmaster, Navitech, Piranha,
Soundmagus is fine, but you have to feed it with an amp that powers 80 RMS, and I think it surpasses your amp, so the most logical JBLs are asking for 50 RMs, removing it from almost any amp.
I think you can drive the rear speakers to the tape output, because the amp will be too much for the rear speakers.
I installed the Forx mid on the front doors to 206, the magnet of the speaker did not fit, I was able to install it with a pulley.
If you can not fit the speaker, you can take the speaker out with a 1 cm pulley.
08.05.2020 20:37 # 8
can0753
Pıoneer power GM-X402 The power values of this amp are as follows; Detailed Technical Specification: -
Continuous Power: 35W x 2 @ 4 ohms 80W x 1 @ 4 ohms
Frequency Response: 20-20,000Hz THD = 0.8%
Input Sensitivity: 0.4 ~ 2V
Filter Types: low pass and high pass
Input Voltage: DC 12V
Fuse Rating: 15A
If he does, I will get the mid team in 1.link if he does not, I will get 2.link.
1.Link: https://urun.n11.com/hoparlor/jbl-cs760c-16cm-mid-takimi-ucfree-kargo-P178229501
2.link: http://www.hepsiburada.com/soundmagus-sm-17c-16-cm-component-takimi-p-OTAKTSM17C?magaza=Hepsiburada&wt_gl=cpc.tum.genel-mobil.pla&gclid=EAIaIQobChMIpdzAm5GKWEWEWE
What values would you advise me to take? can0753 2017-10-31 15:03:47
08.05.2020 20:37 # 9
can0753
[QUOTE = maximusti] I couldn't find an old model power rating but let me say my personal opinion;
Jameson I do not recommend brands like Goldmaster, Navitech, Piranha,
Soundmagus is fine, but you have to feed it with an amp that gives 80 RMS power, which I think exceeds your amp, so the most logical JBLs require 50 RMs power, almost every removes the amp.
drive the rear speakers to the tape output too, because the amp will be too much for the rear speakers.
I installed Forx mid on 206 front doors, the magnet of the speaker did not fit, and I was able to install it with a pulley.
If you can't fit the speaker, you can take out the speaker with a 1 cm pulley.
08.05.2020 20:37 # 10
can0753
Fuse Rating: 15A
08.05.2020 20:37 # 11
ilhanozgur
Hi friends vehicle 206 hatcback front doors kenwood KFC-M614P mid suit
I have my own original speakers on the back doors, 1 set oval sony X-PLOOD on the rear pendulum.
Also, is it necessary to use the amplifier mounting kit for this system with high quality? Can we use something ok?
08.05.2020 20:37 # 12
maximusti
[QUOTE = can0753] Pıoneer power GM-X402 The power values of this amp are as follows; Detailed Technical Specification: -
Fuse Rating: 15A
What values would you advise me to take? [/ QUOTE]
soundmagus 80 RMS, there is no efficiency.
JBL gets more efficient, 50RMS requires power.
