Peugeot 207 manual transmission oil
18.12.2020 17:06 # 1
skystar316
I came across a bad master for the shock absorber and while changing it, the axle was dislocated, I think a lot of oil flowed (I guess transmission oil, I'm not very experienced, sorry :)). And he said that the shock absorber was broken, you went well that way, and said, let's replace 2 of them. I know it is recommended to change 2 of them, but I told the master to change one because I couldn't warm up. It's done. I have a question about this issue: They bought 2 liters of transmission oil and he could not change it, he took it to the next shop and said that he changed it there. (first emptied from the bottom) My problem is this: I guess the gear shifts were worse than before after the change. It seems like it is hard to go to 1. It was beating better with unchanged oil. I think about whether they went to the next shop and changed it. Also, the first gear shifting is very rough after the first run. After the oil heats up, it improves a little, but it is generally troublesome. It is not like before. What should I do? Should I change the gearbox oil again in front of my eyes to another master so that there is no doubt in me? Or is there a measurement of this work as in engine oil? It's been a long time, sorry. Health master for your labor. What is Peugeot 207 manual transmission oil? Is it 75 w 80 or 75 w 90? Best regards… 2009 model 1.4 hdi is at 207 205000 km.
18.12.2020 23:03 # 2
207power
Be sure to change the transmission oil. In addition, it is very wrong to take the gearbox to the side shop without oil, I hope it did not cause any damage. The oil I used in my vehicle is 75-80
18.12.2020 23:47 # 3
skystar316
Thank you very much. I hope there was no problem. I have been riding like that for 1-2 months. I will also have one more question. I think it takes 2 liters of oil, right gearbox? Best regards ... Peugeot 207 1.4 hdi 2009 model
19.12.2020 13:34 # 4
207power
I remember a little over 2 liters.
21.12.2020 09:34 # 5
Hello, teacher. The level of the gearbox oil should be checked from the plug to which they added. I think it would be best to make a complete change. As our friend said, your transmission oil is 75w / 80.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
