Peugeot 207 GT stopped working
25.07.2024 21:19 # 1
t4z35
First of all, assalam alaikum, good evening, I am new to the forum, so please excuse me if I make any mistakes. I will talk about an unresolved problem in Izmir industry. My car is Peugeot 207 GT 1.6 THP EP6 engine. On the eve of Eid al-Adha, the car stalled while driving on the road. I started it again but it reacted as if the battery was missing. The battery is only 1 month old. I waited a little and it started working. After 10 minutes, it stalled again. I took it to an electrician. When they connected it to Launch, the car does not see the engine brain. They said the fuse box in the engine is faulty and we changed it but the problem is still the same. After 5 minutes, it stops on its own. This time, they quoted 20 thousand liras and I did not let it touch it. I took it to my own brain specialist. The brain was opened and checked. No problem appeared. Also, the brain has never been opened before and it is not a tampered brain. After connecting it to my vehicle, the vehicle was fixed but we did not do anything. Only the brain was opened and checked. I drove the car like this for 10-15 days and then it gave the same problem again, it stopped and did not start. We went back to the beginning. The fuse box in the brain was also checked and the wiring was checked. There is no problem. It gave an immo fault. The keys were recoded again and there was no solution. There are active faults on the device and it does not delete, it reads the engine speed but the ignition does not occur. The faults that the device gives are (p1613-p1153-p3014 these are continuous fault codes). (p0113-p0238-p0108- p0117 these are intermittent fault codes) If my brothers and sisters have experienced such a fault, I would be grateful if you could help me.
