peugeot 207 door problem
08.05.2020 19:06 # 1
esoes86
friends peugeot 207 1.4 Hdi even though my car hadn't locked the doors before, when the ceiling light went out, the doors were closing when there was no key in the contact. then I changed the key battery. they coded the key to the vehicle and started working again. This time, the vehicle did not close when you climbed over 10 km. I would fix that problem from some comments here. I kept pressing that button while the vehicle was running and became active again. But the doors are not closing spontaneously at the moment. I get out of the car, the key is on my hand, the ceiling light goes out and I wait for 5 minutes, it does not turn off spontaneously. What is the problem? These problems do not require a mechanic like that, but when we don't know, we give 50 TL to every departure.
08.05.2020 19:06 # 2
BLACK LION
You do not realize that `` the doors are closing automatically '' but I think this is the locking of the doors. As for automatic locking. There is no such system in your vehicle. So it doesn't lock itself when you get out of the vehicle. The self-locking system of the doors works as follows normally:
You lock the vehicle from the control. If you press the unlock button again, the lock is unlocked. However, if you do not open any of the doors within 30 seconds (time may change), the vehicle will lock the doors again for security purposes. He thinks you do not ride, as if your hand was opened by mistake while in your pocket. But this event is disabled when you open one of the doors, it is not locked. You must lock it yourself.
speedy 2015-02-15 16:44:30
08.05.2020 19:06 # 3
Efe-Pojo
Is there an automatic deadlock when it moves in the 207s?
08.05.2020 19:06 # 4
byderebey
[QUOTE = Efe-Pöjo] Is there autolock when it moves in 207? [/ QUOTE]
yes yes .. hold the lock button inside the car while the car is running ... it will sound ding will be active
08.05.2020 19:06 # 5
byderebey
[QUOTE = esoes86] friends peugeot 207 1.4 Hdi Even if my car did not lock the doors before, when the ceiling light went out, the doors were closing when there was no key in the contact. then I changed the key battery. they coded the key to the vehicle and started working again. This time, the vehicle did not close when you climbed over 10 km. I would fix that problem from some comments here. I kept pressing that button while the vehicle was running and became active again. But the doors are not closing spontaneously at the moment. I get out of the car, the key is on my hand, the ceiling light goes out and I wait for 5 minutes, it does not turn off spontaneously. What is the problem? these problems do not require a mechanic like that, but when we do not know, we give 50 TL to every departure, it does not even take 10 seconds .... [/ QUOTE]
After getting on and off the car, it does not lock, but as the friend says, after opening it from the outside, unless any of the doors or baggage is opened, it locks itself again within 30 seconds.
08.05.2020 19:06 # 6
Efe-Pojo
Yes, it appears when it is pressed, but the driver's side can be opened again from the outside, it is impossible to lock the doors from the inside. I didn't understand anything from this job :)
