Peugeot 207 Central Lock Problem
08.05.2020 19:27 # 1
onuralyaz
Friends parked the car yesterday morning, there was no problem.
I opened the door, closed it, did not see it, I tried it many times, it does not see that the door is closed, I played it with a lock, I opened it, I closed it, but it sees the door always open.
I got to the place where I went, I got off the car, I lock the car from the control, it opens instantly, it does not lock the doors since it sees the door open.
I lock the driver door with the key, this time only the doors of the driver are locked, all the doors remain open.
all night the doors remained on the street, the car lay on the balcony, now I have to leave it here because it is safer in the garage of the shop.
If there is an easy way to do it, let me do it yourself, do you have any problems or will I go to the locker? Thanks.
08.05.2020 19:27 # 2
teacher, the switch on the door has malfunctioned or there is a short circuit in the system
08.05.2020 19:27 # 3
vpro
Disassemble the sensor in the door and make it possible when you have time to go again.
08.05.2020 19:27 # 4
ALLEX
Friends, I started having the same problem right now.
If you have the exact information about where and how to insert the door switch, please paylassin. Let's keep the tool but I don't make a mistake if I know how to insert which part.
In addition, everyone can experience this problem, so I think it would be good to fix it under the heading How-To.
If the person is having this problem, I cannot lock the vehicle. I think it is a serious security problem.
08.05.2020 19:27 # 5
vpro
http://forum.peugeotturkey.com/forum_posts.asp?tıd=17282&pn=2&title=merkezi-kilit-sor the
