peugeot 207 abs brain malfunction
08.05.2020 21:07 # 1
kissofflife
friends sitting on the bursa my car peugeot 207 2010 model millimum once had the abs brain repaired at the back of the car at the back of the bench, i was surprised for the second time. would you be
08.05.2020 21:07 # 2
I think it will be better to replace the most beautiful one with an abs brain. it is caused by other errors, possibly causing many errors due to short circuit.
08.05.2020 21:07 # 3
conteo
My past, my teacher, the same situation happened to me. While I was on the straight road, ABS light burned and then flashed from time to time. As a result of a 1-week effort, we replaced it with a solid brain, and it cost me 1250 TL. I know that the original brain is 5binTL from above, and if you find the brain out, it will be resolved.
16.11.2020 20:09 # 4
Adilc.
Greetings, teacher, I have the same problem, how do you handle the problem, can you give information?
16.11.2020 20:17 # 5
ismailkaya
Steering hardening has nothing to do with the brakes, take your car to a good firm in Bursa.
