Peugeot 207 1.6Hdi Black smoke problem
08.05.2020 21:30 # 1
Agresivee
Hello friends, I have a 2006 model peugeot 207 1.6hdi and my car has an excessive black smoke problem. I showed it to 10 masters in 8 months.
The catalyst was drained
Injectors looked at 2 times in 2 different places.
Software views are standard OEM software
Turbo views are solid
Intake monifold cleaned and soot cleaned
Egr views no problem
Egr blinded canceled
Additive was thrown long way was done cyclically
Timing circulation oil maintenance was done
Intercooler checked
These are the things that come to my mind and my car is still smoke, there is no problem in traction and fuel especially traction is very good
Friends, I need a real Peugeot master who will bring this car back to normal in Istanbul.
08.05.2020 21:30 # 2
FatihBall
Hello, we have the same vehicle, I had a black smoke problem that blinded when I loaded to the endless gas in the same way. First, I changed oil etc. I did not recover. Injector return was not much improved. Turbo looked. I cleaned it, then I removed the clean air hose sent to the turbo, the tar you knew was tar, it did not clean the pad spray, etc. I also cleaned it with the help of a brush under water. Use at high speeds You will see the benefit of 3500-5500
08.05.2020 21:30 # 3
Agresivee
First of all, thank you very much for your reply. I did the soot scum cleaning until the suction monifold. I already used würth, but I could not see the benefit. I am already using it in a product that can not be seen at once. Let's see what happens.
