peugeot 206 xs valve?
08.05.2020 14:54 # 1
ozgunn
hello guys i have a question i just bought peugeot 206 xs 2000 model how can i tell if this vehicle is 16 or 8 valves? Overall it was 8 valves, but the friend I bought the vehicle said has 16 valves. thank you.
08.05.2020 14:54 # 2
se®k@n
08.05.2020 14:54 # 3
se®k@n
If the engine is like this, it is 16v. If the top cover is, that is, the cap you see the peugeot emblem is 8v if it is smaller and has less plastic in its appearance.
08.05.2020 14:54 # 4
ozgunn
then 8 valve because the engine is not like that unfortunately thank you very much for your help
08.05.2020 14:54 # 5
ozgunn
but a friend of mine had roland garrs they're 16v right?
08.05.2020 14:54 # 6
ozgunn
I ask for that the image of the engine is the same
08.05.2020 14:54 # 7
roland garros has 8v and 16v. 2 medicine motors were used in both models ... I think in 2001, 8v motor production ended ...
08.05.2020 14:54 # 8
se®k@n
Yes, there are 2 types of motor options in Roland Garros .. There are 8v ones in 2001 model ..
08.05.2020 14:54 # 9
Carmania
You can understand the following way, unscrew the air filter, press the gas, and if you hear the vupoo sound, understand that your vehicle is 16 valves :)
8 VALVE, because the number of valves in the vehicle is low, that sound will not be too much anyway.
08.05.2020 14:54 # 10
I think it is not true :) When I take out the filter of the lada, it hurts and vuuup it. this sound is not related to the number of valves ...
08.05.2020 14:54 # 11
bulent 77
I know it was 16 in 2001, my 2000 xt vehicle was 8 valves. I know the bid is between 8 and 16 horsepower
08.05.2020 14:54 # 12
tigerland
In December 2000, the 1.6-liter 90-HP 8-valve engine was replaced by the 1.6-liter 110-HP 16-valve engine developed by the PSA Group, formed by Peugeot and Citroen. The 206's five-door XT, three-door XS and the specially equipped Roland Garros versions are now available with a new 16-valve engine.
With the improvements made in the top cover of the 8 valve and 90 HP engine, 110 HP power at 5800 rpm and 144 Nm torque at 4000 rpm are produced. The old 1.6-liter 8-valve engine produced 90 HP power at 5600 rpm and 135 Nm torque at 3000 rpm. As can be seen, after the development works, an increase of 20 HP in maximum power and 9 Nm in torque was achieved.
In the first acceleration disciplines of our test, 206 offered more successful values than before with its new engine. Performing 0-100 km / h acceleration in 9.6 seconds as in factory data, 206 was 1.6 seconds faster than before (11.2 seconds). The superiority of the new engine also manifested itself at acceleration of 0-400 meters, where we measured 16.9 seconds. The old engine 206 had completed 0-400 acceleration in 17.5 seconds. Intermediate acceleration. There is no significant difference in the measurements. With the new engine 206, we gained 10.1 in fourth gear and 14.4 s in fifth gear in 60-100 km / h intermediate acceleration measurement. In the eight-valve engine, the winner of this discipline, the values were 9.8 and 12.2 seconds. In the 90-120 km / h intermediate acceleration discipline, we obtained 8.5 seconds in fourth gear and 11.8 seconds in fifth gear. With the old engine, these values were 9.3 and 11.3 seconds. Another difference between the two engines is that the 16-valve version can reach the maximum speed of 198 km / h. The eight-valve engine could only accelerate the vehicle to 185 km / h. Consuming an average of 8.1 liters of fuel per 100 km during the test, 206 can reach a range of 617 km with a 50-liter tank capacity. The old 8-valve 1.6-liter 90 HP engine consumed 206, 9.2 liters of fuel, and its range was 543 km.
1.6 significantly shortened the stopping distance of 16V. We measured the stopping distance at a speed of 100 km / h, which we measured before as 49 m in the 1.4 liter ABS-free version and 44 meters in the 1.6-liter ABS version, as 45 meters at 1.6 16V without ABS. Considering that our test vehicle is Roland Garros, it is really surprising that ABS is not even offered as an option. With the new engine, 206 provides a quieter ride than the old eight-valve engine. The noise level, which we measured as 67 dB (A) in fourth gear at 100 km / h, was 69 dB (A) in the old version. If it was 130 km / h in fifth gear, we obtained 68 dB (A) of data, which is much more successful than the eight valve version of 72 dB (A).
(quotation)
so in this case, 16V
08.05.2020 14:54 # 13
8v motor one out of 16 valve machine only is 8v above the machine compared to 8v machine.
previously, we had the xu7jp machine citroen zx. 1.8 engine 103 hp 153 nm. it produced only this torque at 3000 rpm, and then it rushed at low rpm. Unfortunately, 16v machines give higher torque in the handicap at a higher speed. Unfortunately ... I am riding the 16v of the same machine. Uste cycles are stronger but lower cycles are weaker ...
08.05.2020 14:54 # 14
se®k@n
2001 90 hp with hundreds of 206 present in Turkey .. you can see the ads a lot for sale, if a little research .. The closest one of my two friends 2001 206 XT, one of the 2001 206 Roland Garros there .. the motor Both 90hp 8v ..
08.05.2020 14:54 # 15
tigerland
[QUOTE = se®k @ n]
There are a lot of people who are right, but in the ads, most people mark it without knowing its features. For example, I bought 2000 RG, there is no air conditioner, I went to look at the car.
