*** Peugeot 206 XR LPG Problem ***
08.05.2020 18:05 # 1
okan77
Hello friends
I have a problem with a lpg in a car of a relative. He doesn't do it on gasoline. LPG kit. Aldesa .. When using the vehicle at 100 km or more , for example 4. or 5. When the gear shifts up, that is, when I want to slow down when it reaches a certain speed, or when I need to shift down, the car stops when I pull my foot off the gas and press the clutch while it is moving. There is no problem when I do not take high cycles in urban use. When I go up from the 3rd gear, when I take my foot off the gas and press the clutch, the car stops suddenly. Connected to the computer, maintained, butterfly cleaned, spark plugs changed, manifold reviewed gasket renewed, lpg info. adjustment is made ... Stopping during use has a hard time in traffic ... The problem continues and we need your help ... Thank you
okan77 2013-11-26 10:37:14
08.05.2020 18:05 # 2
seyhanak
the same problem happened in my 206. Atiker checked the service and could not find it. Authorized service finally resolved. They replaced the ignition COIL and spark plugs. It hasn't been repeated in 2 years. I recommend changing the coil ... seyhanak 2013-11-26 10:54:22
08.05.2020 18:05 # 3
okan77
[QUOTE = seyhanak] the same problem happened in my 206. Atiker checked the service and could not find it. Authorized service finally resolved. They replaced the ignition COIL and spark plugs. It hasn't been repeated in 2 years. I recommend changing the coil ... [/ QUOTE]
If there was a coil failure, it would not be obvious in the vehicle before. Or what kind of problem that could not be seen by the eyes, they changed the bobbin ... I had 106 quiks in my head, 3 cylinders with one eye of the bobbin were working car ... There was odor and chills naturally ....
08.05.2020 18:05 # 4
erden1978
I think there's too much air.
If the ramp is doing it in vain, it is definitely because there is too much air.
08.05.2020 18:05 # 5
furkanyakar
You should look at the LPG filter .. it may be clogged. or without firing. It doesn't do it on gasoline because the car runs more precisely at lpg
08.05.2020 18:05 # 6
okan77
[QUOTE = furkanyakar] You should look at the LPG filter .. it may be clogged. or without firing. It doesn't do it on gasoline because the car runs more precisely at lpg [/ QUOTE]
Step 1 filter control is time ... When you say ignition, does the coil need to be replaced, spark plugs have just changed. thank you for your help
08.05.2020 18:05 # 7
okan77
[QUOTE = erden1978] I think there's too much air.
Is too much air coming from the lpg setting? Or is it a different situation? Thanks..
08.05.2020 18:05 # 8
okan77
Anybody have an idea?
08.05.2020 18:05 # 9
okan77
Friends, the problem still continues. Necessary changes were made.
it just doesn't always do. so he can do it while going too fast, sometimes he can do it when he slows down to enter the street, he can do it when he comes to the church .. He did it again, he can work next time
I mean, as if there was an interruption for a moment, it does not matter whether it is uphill or down ...
okan77 2014-02-14 14:42:39
08.05.2020 18:05 # 10
seyhanak
There are two possibilities.
First of all, the electricity of the Lpg system may have been taken from the wrong place in the fuse box under the steering wheel. First, have it checked.
If the electricity is taken from the right place, you should replace the coil, and if your spark plugs did 20-25 thousand km, replace them as well. Constant knowledge with experience .....
08.05.2020 18:05 # 11
muhammed.ceyhan
If the vehicle drops too much (like stopping) while passing from gas to gas, the cables of the gas injectors are reversed. I personally lived. it is fixed by experience.
08.05.2020 18:05 # 12
muhammed.ceyhan
make sure that the injector wires are correct.
08.05.2020 18:05 # 13
koramiral
The gas outlet nozzles at the tip of the lpg injectors may be due to being wide or narrow.
vice admiral 2014-03-01 17:04:40
