Peugeot 206 when the wheel turns, the voice of CIK CIK !! K
08.05.2020 19:45 # 1
FuRiouS
Friends, please help, I'm about to go crazy.
You know what's in the car, the front set of disc pads have changed them all. Right after the vehicle came out, the right front wheel started to come out. The wheel feels like it is hitting the ground as it freezes, but we checked the wheels, any stones, etc. sıkısmamıs.
What does this rogue voice come from?
08.05.2020 19:45 # 2
usta307
If my brother has a steel rim, check the rim of the rim.
08.05.2020 19:45 # 3
ALLEX
[QUOTE = usta307] If my brother has a steel rim, check the rim of the rim I searched for 6 months, the rim of the rim was mixed with the gel of the cigarette, the sound stopped [/ QUOTE]
Master tolerated correctly. If the rim of the rim of the rim is more than it should be, the tolerance between the seating cap is more than it should be.
If it is still not cut, it offers the remaining possibilities.
1- Is it suitable to fit the ball balls and balls tightly to the hub?
2- It may not be visible in the disc assembly, but if the parallelism in the disk is not zero, this is the strongest possibility.
You can have a compressed check on the grinded surface or on the lathe chuck.
According to my name, parallel control is done for every part in CNC mold manufacturing.
As the master says, start from the rim hub to look for the problem.
If you share the problem here, it will be permanent information.
Thanks to everyone who reads.
08.05.2020 19:46 # 4
FuRiouS
Problem solved :)
Caliper is saying bullets on the rim.
