Peugeot 206 upper cylinder seal
08.05.2020 20:56 # 1
unalt
I guess the top cylinder gasket was burnt on my 2000 model car, it is throwing water under the car's belly, yesterday I made 4 liters of water, what would be the cost if I hit the master, did anyone change it in the new time Ünaltuna 2018-07-05 08:11:58
08.05.2020 20:56 # 2
My teacher has an average cost of 1000-2000 TL, it is difficult to say something without disassembling. it is likely that these processes will change in timing and circulation. I hope there are no problems in the eccentric - valve and cylinder seats.
08.05.2020 20:56 # 3
GokhaN
cover acma starts from 1000 an estimated amount of 2000-2500
08.05.2020 20:56 # 4
seroline
Hello brother, I had the problem of mixing oil into the engine water, since 1 month ago my cylinder cover was rotting. I behaved a little early and my problem ended with little expense.
Cover gasket: 65 lira (get original - get it from the service)
Disassembly-workmanship: 700 pounds
Timing set: 185 pounds (changes when timing seal is renewed)
Oil-oil filter: 125 pounds
Since my car did not overheat, I got over it cheaply, if your car was overheated, the cover will be stoned (average 200-300 lira).
