Peugeot 206 Trip Computer - com2000 key construction
08.05.2020 15:53 # 1
cuneytatay
Hello friends,
I've been dreaming of a trip computer for a while Sırıtma I read all the topics in the forum, when I said whether or not, I read the last of the words of the cookie. There he was talking about the com200 handle without changing the button on the end and installing the software, so that we can use the trip computer. Ouch After the 2nd or 3rd page, it was stated that this arm is in the 307s and the 206s are different models, if we disassemble it, the tip of the arm will break. Wall
I started trying by saying that I can do it without breaking the button, without paying for the arm or button.
First I bought a 3-line information screen, then I went to the industry and activated the trip computer.
Then I started to disassemble the arm Gülme
The materials we need:
Flat screwdriver
Spring ball pen
Smooth file
nippers
Pliers for pliers
First, the button part at the end of the wiper arm will be removed with a flat screwdriver.
there are tabs on both sides of this button, carefully remove from the edge without pressing too much
There is a small hole where we remove the button. First of all, we make a test with a thin pen (plastic) coming out of the ballpoint pen.
then there's a little bit where the button pops out, we'll break it
break this little piece with the pliers of pliers
this little piece is one of the pieces that prevents the button from going forward
the second part to break is the protrusions under the button
(Do not look at the pedestrian next to it, it was an experiment, it was not used)
After breaking these pieces, the bottom of the button flattened
Clean the file and the tabs on the bottom and side walls of the button
button cleared
then we take a spring ball pen and disassemble it, cut a piece of 2.5 cm from the back of the pen, and divide the spring from it into 2.
We expand the part of the spring cut with a pair of pliers so that it can be easily placed next to the nail on the arm and not to fall.
then we install the spring and the plastic of the pen in its place.
[TUBE] Fx-dc6uyk6k [/ TUBE]
Good luck with.
cuneytatay 2011-07-27 17:33:40
08.05.2020 15:53 # 2
dinoco
I would like to shake your hand, not a greeting.
08.05.2020 15:53 # 3
cuneytatay
you are welcome, we share what we know Clown
now let's go and pack the car
08.05.2020 15:53 # 4
metin
congratulations cüneyt. You have explained it in a very nice and descriptive way and even overcome the breaking problem which is the nightmare of 206 owners. ,
I would like to ask the managers how to do it.
Also, as far as I can see on the screen, the outside temperature indicator does not work. I don't know if you researched it, but I couldn't remember how it was done on our site, but there are illustrated expressions about making it active. If you did these things, make the temperature indicator complete.
08.05.2020 15:53 # 5
cuneytatay
Thank you, my teacher, yes, I have researched before, I read the article in the how-to section, how to do it, memotech wrote, I will take it on my day, let's spend so many days today :) cuneytatay 2011-07-27 18:03:12
08.05.2020 15:53 # 6
only_younus
[QUOTE = Dinoco]
+1
08.05.2020 15:53 # 7
Congratulations. So there's nothing to say. Would it be all Approve
Jove billahi bravo Stern Smile
08.05.2020 15:53 # 8
lkr_yldz
REAL CONGRATULATIONS. AND I WISH YOUR SUCCESS CONTINUED. BUT YOU WILL HAVE A QUESTION WHEN IT IS RELEASED, IT DOES NOT STOP IT. AND THE LATEST QUESTION HAS ACTIVATED THE ROAD COMPUTER IN THE INDUSTRY.
08.05.2020 15:53 # 9
lkr_yldz
VEDE WHERE I WANTED HOW TO CONNECT WHERE AND WHERE THE 3.5 MM JACK CABLE FROM THIS VENTILATION :)
08.05.2020 15:53 # 10
cuneytatay
[QUOTE = lkr_yldz] HOW AND WHERE IS THE FACILITY OF THE 3.5 MM JACK CABLE FROM THIS VENTILATION:) [/ QUOTE]
that jack is connected to the crystal input of the tape :) when the tape is placed in the tape player position, i connect my phone with that jack and listen to mp3 Star
08.05.2020 15:53 # 11
cuneytatay
[QUOTE = lkr_yldz] REAL CONGRATULATIONS. AND I WISH YOUR SUCCESS CONTINUED. BUT YOU WILL HAVE A QUESTION WHEN IT IS RELEASED, IT DOES NOT STOP IT. AND THE LATEST QUESTION HAS ACTIVATED THE ROAD COMPUTER IN THE INDUSTRY. [/ QUOTE]
Thank you, there are no nails on the edges of that cover, I made it in the industry behind the traffic branch office in the adapazar.
08.05.2020 15:53 # 12
cuneytatay
[QUOTE = koliva] Congratulations. So there's nothing to say. Would it be all Approve
he he Sırıtma
08.05.2020 15:53 # 13
MemoTech
You have done a very good work and I congratulate you with sincerity. I did not dare to break the com, give the old and buy the new. So you got the courage back. I say halal.
In the meantime, if you have problems with the outside temperature, I can help you. Good luck with.
08.05.2020 15:53 # 14
metin
[QUOTE = MemoTech] You have done a great job, I really congratulate you. I did not dare to break the com, give the old and buy the new. So you got the courage back. I say halal.
In the meantime, if you have problems with the outside temperature, I can help you. Good luck. [/ QUOTE]
wanted people found Kahkaha
08.05.2020 15:53 # 15
MemoTech
What gems are there in this forum, ah ah maşallah let's say it is not worth it.
I swear there are a lot of authorized and unauthorized service personnel who do not even know about the existence of the applications we do here. These elements can get rid of being ineffective elements if they stop there. :)))
08.05.2020 15:53 # 16
mehmet1965
Friends, I was French. In this regard, Cuneyt Senir, did the car have 3 lines of screen or not? can the road computer be activated for every 206?
08.05.2020 15:53 # 17
Ozgur
Trip computer that will not be under 2003.
It can be applied from the end of 2002, more precisely.
There is a 3 line display every 206.
There are models such as rc, gti, quicksilver.
08.05.2020 15:53 # 18
lkr_yldz
A storm of excitement started to break in me again :)
08.05.2020 15:53 # 19
cuneytatay
[QUOTE = mehmet1965] or friends, I was French, did you have 3 lines of screen in the cuneyt senır car? can the road computer be activated for every 206?
There was no screen in my car, I bought it later, as far as I know, the trip computer does not happen for every 206, 2003 and later, its infrastructure is not compatible, the masters wrote more detailed answers.
08.05.2020 15:53 # 20
Congratulations, sir. A big study you brought almost a piece ranging from 150 to 400 TL Gülme
My vehicle 206+ I did not try to disassemble the button part, but I even tried to disassemble that rotating part of the wiper arm. So it's not easy to disassemble like yours. I haven't tried it, but I think it's never been removed. Is it still possible to do this process?
Page : / 19
