PEUGEOT 206 TITREME |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 19:14 | # 1 |
My vehicle also had a fluctuating idle that I had been feeling for a long time. In LPG, the vehicle is almost silent and can be sold. To solve this, I changed it to the penzin pump, but there is no change ... Spark plugs are new to the coil. Could there be an injector malfunction, how can I solve this problem ..? started to bother thoroughly now ... ![]() ![]() ![]() |
| 08.05.2020 19:14 | # 2 |
No one has an idea? |
| 08.05.2020 19:14 | # 3 |
I had the same problem idle sensor oxygen sensor changed no problem left service throat throttle crank sensor will be changed, gave a price of 1600 tl, out of 300 tl was resolved
| 08.05.2020 19:14 | # 4 |
Hello there, I thought you were talking about and even cleaned the throat butterfly, but the problem persists, meanwhile, when the LPG passes, the vehicle works comfortably. |
| 08.05.2020 19:14 | # 5 |
It is not a problem to clean it, but a sensor in the butterfly will have a problem with it. |
| 08.05.2020 19:14 | # 6 |
sonerkyl |
I struggled a lot with these kinds of problems, not just pugs. It's happening in other vehicles. 1-Vehicle gas breakers can cause gas leakage. This creates imbalance in idle, since both gasoline and gas will come to the combustion chamber. (at the first start) 2-Map sensor is faulty. I think you can look at them too.
