Peugeot 206 tape digital
08.05.2020 19:49 # 1
fatihc88
My brothers, I got a suitable type of temporary piranha troubled situations, so my question is, when I turn off the tape, the digital clock stays on.
08.05.2020 19:49 # 2
Mrttt53
I would recommend you to have the tape connected to the contact wherever the watch is on. I have the pioneer connected to the contact. The original tape closes as soon as the contact closes or mine closes 1 2 minutes after the lock is closed.
If the information screen does not turn off, the card inside that screen was burned, I had the problem, I had removed the battery terminal as a precaution for the battery to run out.
08.05.2020 19:49 # 3
fatihc88
When I connect the tape to the contact, is the problem solved? In my digital console, the km indicator is always on, the numbers are burning.
08.05.2020 19:49 # 4
Mrttt53
If you connect the non-original tape to the contact, the contact closes, the doors close, the tape shuts itself off 1-2 minutes after locking. 1-2 minutes later than the original tape.
The mileage indicator should go off 1 minute after turning off the ignition. If you open the door after turning off the vehicle, the km indicator will light up again.
08.05.2020 19:49 # 5
samet206
As long as the tape is connected to the contact, even if you do not manually turn off the key as soon as you remove the key, it will cut off the energy. plus the tip and the memory tip are connected and the disconnection of these must be connected to the relevant places. When I first bought the car, the same connection method was made to me. The clock was showing on the screen. It did not happen for 8 months. One day I got into the car. Then I put the tape in contact and then I had no problem.
samet206 2016-06-03 01:19:53
08.05.2020 19:49 # 6
Cyrus35
If the tape works when you turn off the lights, you should add the clock mode. You can search from the set of settings. I have a Pioneer tape on it, while I was in off mode, the date was on, and I turned it off. The same may be the case.
08.05.2020 19:49 # 7
Alicilik
What is the vehicle?
After 2002 206
307 partners from 2002 to 2005
In the power of the 8-iso socket, the memory next to the chassis is constantly feeding +12. The bs trigger is below 2 or below 2. If you connect the ac capacity of the tape to this, the tool will turn off 1 minute after locking it.
