Peugeot 206 Strange Problem Please Help
11.06.2025 17:08 # 1
muratatalay
Hello dear forum members. I need urgent help from you. What can I do, what is the solution? I have a Peugeot 206 1.6 CC (Cabrio). The part you see below is the air conditioning evaporator sensor. For some reason, while all Peugeots use a different sensor, this one has this metal part with a mercury tip. This part is also used in the Citroen Xara brand. It is not sold in Türkiye. It is not available in any dealer. This part is broken and currently my air conditioner is running, the compressor is gas and everything is ok, but the air conditioner is not blowing cold. I think this part is the part that detects the temperature and switches between the heater and the air conditioner. The air conditioner is blowing full hot whether it is on or off. I have tried a few things. 1- I cut the wire that has this connector and reconnected it, hoping it would detect it as a switch, but to no avail. 2- I soldered this connector from the broken part and reconnected it, but again to no avail. 3- The air conditioner gas was checked. The problem is exactly this part, not anything else. WHAT SOLUTION CAN BE PROVIDED? WHAT IS OUR PROPOSAL FOR A SOLUTION? CAN WE SOLVE THIS ISSUE BY USING ANOTHER EVOPARAOR? muratatalay2025-06-11 17:15:29
