peugeot 206 stops automatic gear shift
08.05.2020 19:17 # 1
ercanayaz
Mrb friends I am using 2008 model automatic gear 206 ... the car stops when I press the gas after stopping at a low speed ... recently it started to be twice a day ... is there any problem with this problem ... what is my solution ... thanks... ercanayaz 2015-05-17 19:51:44
08.05.2020 19:17 # 2
talip206
It happened to me a couple of times after I got lpg. Then they took it to where I got it. They did not happen again. If your vehicle has LPG, adjustment may be required. Normally, automatic vehicles do not stop on departures.
08.05.2020 19:17 # 3
ercanayaz
I have a lpg, aspiring teacher, let me get a glance ... thank you ... did the engine feel like a boguluyo before you stopped too ...?
08.05.2020 19:17 # 4
ebay otomotiv
If your vehicle is 1.4 and have you recently changed the timing belt, and what is the km of your vehicle, I try to help you
08.05.2020 19:17 # 5
talip206
There was no shaking in tremors, it was as if gasoline was gone and it was like a click. Once it stopped, he stopped again once in a while. After connecting the LPG to the computer, he changed the place of a few hoses and made the adjustment never stopped. talip206 2015-05-17 23:06:04
08.05.2020 19:17 # 6
ercanayaz
Teacher, my car was 1.4 ... 74 thousand ... 69 thousand I bought it for 4 months ... I asked the person I bought trigger apricot .. I changed it ... he said to his neck ... I did not check the apricot ... ercanayaz 2015-05-17 23:12:02
08.05.2020 19:17 # 7
Serkan
Generally when the air conditioner is turned on and only stops at lpg, it is necessary to make the return setting from the lpg cut offs, most lpg tuners do not know this feature in the software and when the summer comes, stop stops on the lpg cars, when you go to the lpg settings, talk about the setting when you come back from the cut off, Get information from the master.
08.05.2020 19:17 # 8
ercanayaz
My air conditioner stops when it's not on, my teacher ... Did you think the cut off problem would occur when you didn't use the air conditioner ...?
08.05.2020 19:17 # 9
Serkan
If the air conditioner is turned off, if it happens 1 time a day, it was 3-4 times when it was turned on.
08.05.2020 19:17 # 10
ercanayaz
okay teacher I will try the air conditioner ...
08.05.2020 19:17 # 11
ercanayaz
Friends, the car's oil has just changed ... Could this problem be related to the oil ... what should I do
