Peugeot 206 Steering Wheel and Com2000 Installation
08.05.2020 14:02 # 1
hasimayaz
Before starting the operation, let's first note that the ignition key is not attached. Then let the vehicle pass to ECO MODE and let's disassemble the battery completely.
hasimayaz 2009-03-24 11:36:30
08.05.2020 14:02 # 2
t@lip
Thank you very much, Mr. Sir, it will really benefit me a lot.
08.05.2020 14:02 # 3
hasimayaz
[QUOTE = Talip_019] Thank you very much, Mr. Sir, it will really work for me [/ QUOTE]
You're welcome .. I hope the problem comes out of com2000 .. Hopefully there is no problem with BSI. BSI also makes you work very hard because it is involved in immo and software. Com2000 should be tried first. It is impossible to understand without trying.
Good luck with..
08.05.2020 14:02 # 4
HakanGokdemir
Health to your hands, Haşim ...
08.05.2020 14:02 # 5
Emin
08.05.2020 14:02 # 6
mod55
Good health Haşim brother :).
08.05.2020 14:02 # 7
master
The key hub is making a serious noise on the rough road. Is there a nut or a part that we can tighten in this way?
08.05.2020 14:02 # 8
hasimayaz
[QUOTE = master] The key hub is making a serious noise on the rough road, Is there a nut or a part that we can tighten in this way acep *? [/ QUOTE]
There is a receiver antenna and transponder outside the hub, all of which are connected to the body with a single screw. Screws and connections can be checked.
08.05.2020 14:02 # 9
master
[QUOTE = hasimayaz] [QUOTE = master] The key hub is making a serious noise on the rough road, Is there a nut or a part that we can tighten in this way acep *? [/ QUOTE]
My Hashim, you put a photo on it now :)
