peugeot 206 steering wheel
08.05.2020 19:35 # 1
fatihc88
Selamin aleykum gentlemen when I knock the steering wheel of the peugeot 206 min until the very end, it sounds like a plug.
08.05.2020 19:35 # 2
samet206
If you break the steering wheel and give it gas until the very end, it is normal, even when it is made too hard, this movement will sometimes occur even if you do not gas. Standard is a normal situation.
08.05.2020 19:35 # 3
fatihc88
Thanks, samet brother, I will put the car into the maintenance, it is a bit difficult to switch the bidet gear.
08.05.2020 19:35 # 4
samet206
If you are going to be in maintenance for this, as I said, I do not know what everybody's car is making this sound, but obviously, this is the vehicle. I don't know how much, but the transitions are somewhat bony, and the transmission oil gear bar changes a little bit in 206. Then, you can have a look at the gear pad gearbox, something will be done accordingly.
08.05.2020 19:35 # 5
fatihc88
Thank you very much bro, because I do not know the water of the car, I will get help from you, I will consult the bole issues as I said.
08.05.2020 19:35 # 6
samet206
I would like to ask you to write comments for other support users.
