peugeot 206+ starter is not working help ..
08.05.2020 21:21 # 1
adem868
Friends on my peugeot 206+ 2011 model car, the wipers started working on the road. The instrument panel of the vehicle flashed and dipped headlights hurt. The wiper arm signal arm horn stopped working. After a while it stopped spontaneously then started to repeat it. When I switch on the ignition when I go to work in the morning after parking, the indicator lights are on, dipped beam headlights are not open horn. I called the master, connected to the computer, tried to delete the record of the fault, 10 days later, the same thing would be repeated. I changed 3 masters couldn't find the supply. Could someone who knows that my vehicle is lying down and does not work?
08.05.2020 21:21 # 2
adem868
does anyone know?
08.05.2020 21:21 # 3
omerb
hello, have you checked the battery? Peugeot likes a powerful battery. It also happens if the battery does not fully transmit the pole. I think you can test the battery by reinforcing it when it is not working.
Because I had that wiper work, etc. We changed the battery, the problem is gone.
Also what were the malfunction codes that came out. Try a reinforced shape first. If not, please write down the fault codes.
08.05.2020 21:21 # 4
adem868
I will try and return with reinforcement. I learn and write the supply code thank you
08.05.2020 21:21 # 5
omerb
If there is a problem with the fuel or ignition system, the vehicle does not make silly movements. Such as turning on headlight, wiper operation, not working.
This seems like a sign of electrical malfunction. I hope we will be right. You don't bother much.
08.05.2020 21:21 # 6
YNR
The circuit may have short-circuited and, accordingly, the fuse related to the immobilizer may be blown. If it is a battery, it does not margin. it is all about the fuse that has exploded as a result of the brain or short circuit .. Disconnect the battery terminal and remove it for 10 minutes. then plug it in and try once more ..
08.05.2020 21:21 # 7
First of all, welcome to us. the problem probably seems to be in the brain. If you are in Ankara, there is a Mas peugeot in the car. they will solve the problem of your vehicle.
08.05.2020 21:21 # 8
adem868
The problem with the headlight wiper arm control has been solved thanks.
08.05.2020 21:21 # 9
GokhaN
[QUOTE = adem868] Malfunction of the headlight wiper arm control has been solved thanks. [/ QUOTE]
get well com2000 failure is already chronic
