Peugeot 206 + Starter
08.05.2020 19:24 # 1
burakbaykal2
Good day everyone. Last night, after a little shopping, I turned off the engine and entered the market. When I got out, I said, I would open the contact again and continue, but although the vehicle was diesel, it turned the starter dynamo several times, not like the first starter like gasoline vehicles. When the engine was cold in the morning, the car did not get on the first contact and the first starter, which never happened to me. After the 2nd starter, it continued to work without any problems. I changed the battery this time last year, is the battery started to decrease again or is there any problem with the starter?
08.05.2020 19:24 # 2
you can measure the battery, teacher or look at the starter dynamo.
08.05.2020 19:24 # 3
Turgutreis06
I also suspected the battery ...
08.05.2020 19:24 # 4
burakbaykal2
I just came from my master, checked the input and output filters, looked at the spark plugs (diesel). When I say everything is normal, 3-4 months ago, I had these switched keys because I don't have a spare key and I want an alarm. hence the immobilizer was also inserted into the new key kit. Now when he wanted to start the car with the key logo facing up, the starter pressed normally but did not start, he said stop, he put the key in reverse, that is, the car worked normally with the logo facing down. Now I will try the original key at home, put the evening chip in its key and try again. If this is the solution, I will inform you again, many thanks for the advice, guys.
08.05.2020 19:24 # 5
burakbaykal2
If I think it's an event, that's all ...
https://www.youtube.com/watch?v=_rcqkahlxks
08.05.2020 19:24 # 6
burakbaykal2
I have forgotten to say it has been solved, but I wanted to write it again so that it wouldn't panic if it happened. The incident was due to the key and immobilizer. When I realized that it was not fixed in the slot inside the spare key and inserted it into the original key (I had an alarm key, the problem was in it), it returned to its normal order.
08.05.2020 19:24 # 7
This pug is very strange tools or .. I am glad you have solved your problem.
