Peugeot 206 shaking and engine light blinking
11.07.2022 01:24 # 1
ouzqan
Hello everyone, we took out the second vehicle of the house, the 206, as a holiday, and after a few trips, we decided to start it. Even when the engine was on the road, the vehicle started to shake from the exhaust and the engine light started to flash constantly. What do you think is the reason ?
The vehicle is 1.4 petrol+lpg 206 desire package at 232000 km
12.07.2022 15:51 # 2
talip206
Ignition malfunction.
Because of spark plug or coil failure.
If you connect it to the device, it will tell you which eye is the problem
14.07.2022 01:15 # 3
ByYlmzZz
first connect the vehicle to the device so that it will tell you its problem. If there is shaking in both LPG and gasoline, it is necessary to concentrate on ignition. But it may also be caused by the knock sensor.
