Peugeot 206 Sedan friends need help
08.05.2020 20:09 # 1
sanal_kral
Hello friends car 206 sedan 1.4 gasoline 2010 model km 115.000 and I will be glad if you have some questions. Regards.
Friends vehicle was about 9 10 months when I bought the vehicle was at 105.000 km and we were sitting in the same place with the friend I bought the vehicle is from the first owner and now it needs to change oil at 115.000km and the filters need to be changed to me in the booklet it gave to me and before I buy the vehicle, the oil change at 105.000 I want to get an idea from you because I will put the vehicle into maintenance.
1.The trigel set of the vehicle has changed the brake pads at 93.000 km and the V-belt has been changed at 105.000 km, is there anything to do about them?
2. The car oil is written in the castrol 5w30 booklet so when I look at the internet, there are 2 kinds of castrol 5w30 which one should I buy, normal green, there is an edge, I want to change all the filters in the yellow change, the other 206 and the sedan 206 filters are the same?
3.What steering oil and brake fluid should change which oil should I buy?
4. When I do not get in the car for 3 or 4 days in very cold weather, I wait for a while when I start the car for a while, when I move with the car, I have difficulty in switching to the 1st gear, does it get better, do I have to look at the transmission oil or is it normal in cold weather?
5. Friends right dipped beam bulb exploded How can I insert the bulb myself, I want to take it and change it, regards.
sanal_kral 2017-01-30 13:50:23
08.05.2020 20:09 # 2
No need to take any action for 1-question
You can use 2-green ones, the other 30-40 TL is more expensive but you can get a better quality oil if the material situation is good. I do not use other oils than mobil and castrol two companies, but generally I prefer mobile, the price is a bit more affordable. In other filters, the air filter will be long type, teacher, gasoline and pollen filter are the same.
http://www.peugeotmarket.com/peugeot-206-14-benzınlı-bakım-setı-2004-orjınal,pr-413.html
It is referred to as atf for the 3-steering wheel, but if the level is correct, there is no need to change it, you should get dot 4 for the brake.
4-It is caused by colds and in that case you have it checked for peace of mind.
You need to buy a 5-h7 bulb, you can change it yourself. There are necessary details in the link I provided.
http://public.servicebox.peugeot.com/ddb/
sonerkyl 2017-01-30 14:47:41
08.05.2020 20:09 # 3
sanal_kral
Tsk thank you, I got the necessary information, hodja finally where can I get the filter set for the car, the filters are the same in all 206s
08.05.2020 20:09 # 4
[QUOTE = virtual_kral] Tsk thank you I got the necessary information my teacher finally where can I get the filter set for the car all the 206's filters are the same [/ QUOTE]
you are welcome now i noticed i put my fix message and link Thumbs Up
08.05.2020 20:09 # 5
OguzhanKucuk61
Filters are the same teacher. Maybe the pollen filter may be different. I think it was the kind of framed.
