peugeot 206 rolland garros 1.6
08.05.2020 15:11 # 1
pele001
peugeot 206 rolland garros I own a car, I traveled 20 km with gasoline, 60 km. Ouch
08.05.2020 15:11 # 2
masumserseri
Normal. The price of air cold plus gas is high. Thumbs Down
08.05.2020 15:11 # 3
Welcome to us but I wish you had introduced yourself first
08.05.2020 15:11 # 4
[QUOTE = pele001] peugeot 206 rolland garros I own the car, I traveled 60 km to 20tl with gasoline, the average city km / tl is 333ykr, this is not too much, why should I help my friends who know if I am hungry, if I care or adjust, please. Ouch [/ QUOTE]
Yes, my beautiful brother. If you introduce yourself as per the forum rules, we will try to help you
08.05.2020 15:11 # 5
pele001
Do not look ksr, I did not look carefully, the rules,
but I introduced myself it was late but ......
08.05.2020 15:11 # 6
Let's come to fuel consumption. According to the vehicle's 2000 model, I think that the 8V machine is 90bhp. 33kr per kilometer you have said is a very good figure and in the city ... what more do you want ??? :)))) Approximately 8l at 100km.))))
08.05.2020 15:11 # 7
pele001
If you have a suitable diode gas system, I would like to notice half the penzine in the vehicle. Which system would you recommend?
08.05.2020 15:11 # 8
Of course, I believe the vehicle will be more economical with LPG.
08.05.2020 15:11 # 9
[QUOTE = pele001] If you have a suitable diode gas system, I will notice half the penzine in the vehicle. Which system would you recommend? [/ QUOTE]
Doesn't matter half. Because the LPG prices have risen compared to the past. If you have a quality installation, you will save up to 40%. Cars with more consumption of gas are saving more on a monetary basis ... if you are going with 8 LT in gas, you will go with roughly 9 LT in lpg ...
but you need to find a skilled master for assembly. It has 1.6 8V motor full group spraying. You can use wasteers such as safe fast, lovato, zavoli etc. The new my-10 software is out on brc. you can research it too ... if you can make their lambda connections and run it as automation, it can be more smooth ...
08.05.2020 15:11 # 10
axi206
I think your fuel is normal. I also have 1.6 16v 206, burning almost the same. with longitudinal tank fuller method; I burn 35 tl of fuel at 100km with an open air filter and 28 tl of fuel with the original filter. In the city, I couldn't get under 350 kurus, but I can't use it.
08.05.2020 15:11 # 11
xdesign
I'm going 80 km for 30 TL, I think it is quiet with 1.4 :)
08.05.2020 15:11 # 12
I have 206 Quiks. 1.6 110HP. Around 32 cents in the city.
08.05.2020 15:11 # 13
kuzgun
Hello
I made 180 km with 206 cc and 100 TL gasoline, the needle is just above the level before 0 and the light is on, is it used until that level, and then is there a little more road to go down to 0? I am willing to wait for your comments I guess I shouldn't expect more.
08.05.2020 15:11 # 14
[QUOTE = raven] Hi
100 TL = 22 liters. So your vehicle burned 12.2 / 100 km, which is a bit too much. Are these values urban or the long way? Also, try not to drive your vehicle from the quarter warehouse.
08.05.2020 15:11 # 15
werty
I use 1.6 quicksilver. When I use it very carefully, I dropped 100/7 lt. But I tried very hard.
normal use burns around 100 / 8.1. Of course, the fuel plays 1 2 points in proportion to the maintenance of the car. The average goes 30 = 100 Km.
08.05.2020 15:11 # 16
kuzgun
[QUOTE = koliva] [QUOTE = raven] Hi
Thanks a little too much to me, so I felt the need to ask is this data is city data.
08.05.2020 15:11 # 17
kuzgun
by the way, what is its normal level? I wonder if I need to have maintenance, the car is showing 11.000 km more to go to the maintenance. Big smile
08.05.2020 15:11 # 18
[QUOTE = raven] By the way, what's the normal level? I wonder if I need to have maintenance, the car is showing 11.000 km more to go to the maintenance. Big smile [/ QUOTE]
You can also try your car outside the city, and let's see those numbers and comment accordingly. Because when you say the city, a lot of different things come to mind.
As far as I found on the Internet:
out of town 6.0 liters / 100km
10.6 liters / 100km
08.05.2020 15:11 # 19
werty
You have to change the filters of a 10.000 km oil. If you change the spark plugs in an oil change. the oil in it was coal.
08.05.2020 15:11 # 20
kuzgun
[QUOTE = werty] [QUOTE = raven] By the way, what is its normal level? I wonder if I need to have maintenance, the car is showing 11.000 km more to go to the maintenance. Big smile [/ QUOTE]
Thank you very much, I will have another question, I want to receive news when I reply to this article. What should I do to return immediately? Tongue
Page : / 2
