Peugeot 206 remote control
08.05.2020 18:01 # 1
mstfylmz
Hello friends,
3 days ago, I lost the keys of my car and went to the service and took out the keys again.It only gave me 15 days for the key to come from France. can I have it done externally? I need your information on this subject thanks ...
08.05.2020 18:01 # 2
Mesut48
There are places in the industry that sell control vessels. They can help you.
I bought 206 control vessels at 50 tly.
08.05.2020 18:01 # 3
Serkan
Yes, you can have it installed from the system that auto electricians install on hawk and broadway style vehicles, you do it on the new control that they will give you, not the original control.
08.05.2020 18:01 # 4
osmntskn
my teacher, every man can't do it
I took it to my relative, he burned three alarm brains, then he investigated the left and right, and we had it done to someone else. its binding is a bit troublesome compared to other cars, but it happens.
40 pounds device
I gave 40 workmanship
There is also a backup. awesome
08.05.2020 18:01 # 5
mstfylmz
Thank you very much for the information. Only my vehicle has a central lock. Or should I have a central locking system again?
08.05.2020 18:01 # 6
Serkan
They do not touch the central lock, my teacher, they wear a small module, they control two of them.
08.05.2020 18:01 # 7
Mesut48
[QUOTE = Serkan] They do not touch the central lock, my teacher, they wear a small module, they control two. [/ QUOTE]
Is my teacher Serkan a key chip in your friend's hand?
If it is chipped, does not the problem can be solved by buying a door and transferring the chip?
I have a spare key I want to make it controlled. ok :)
08.05.2020 18:01 # 8
Serkan
Mesut Hocam, the key in the hand of the friend only has an immobilizer chip, there is no remote control circuit, so even if the key takes the container, it only transfers the chip into it and the key is again without control.
08.05.2020 18:01 # 9
mstfylmz
Exactly, I have to have a remote control kit. I have to go to the industry, it has an estimated cost of 80-100 TL. Thanks friend :) You, you, don't lose your keys :)
