Peugeot 206 Rear Door Trim Removal
08.05.2020 14:02 # 1
hasimayaz
http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=41
08.05.2020 14:02 # 2
Ozgur
master, I just tried, I applied them all ..
Is there any clip from inside?
I do not have removal pliers by the way ..
that is, I removed the frame on the door handle, the whirlwind that used to close the other door. But I could not remove the upholstery.
I would appreciate if those who know can help me urgently .. my car is waiting for help .. thanks
08.05.2020 14:02 # 3
hasimayaz
It doesn't come out when you say so .. Starting from the bottom, insert 4 fingers between the body and the floor and force it out. Take out the circle by drawing a circle .. there is no clip on the top, the sides and the bottom are snapped, then lift up and remove the floor.
If you do not have a clamp, it is likely that a few nails will break. It is sold in the industry.
08.05.2020 14:02 # 4
Ozgur
I pull it up, I understand.
I guess the things that hold the clips .. like you said on the top.
I am not hung up by fear. Now we will pull out slowly.
As you said, Kırcaz is now a few clips .. Thanks for your help.
08.05.2020 14:02 # 5
Ozgur
THANKS FOR YOUR AID..I WANTED I MADE IT FROM THE CLIP BREAKING
08.05.2020 14:02 # 6
furkan4607
the subject is a bit old but i will write anyway. I dismantled them all but I just couldn't knock these glass arms there are 3 pieces inside the notch. I couldn't disassemble it. Can you help me?
08.05.2020 14:02 # 7
Bugra
it has circlips you need to apply some force to get it out
