Peugeot 206 oxygen sensor map sensor
06.01.2022 01:14 # 1
Mesutaslan
Friends, Peugeot 206 automatic gear transmission 1.4 petrol 2004 model vehicle, I want to know if the sensor oxygen and map sensor are faulty or not. Who is doing this? Does anyone knows.
10.01.2022 17:00 # 2
Hello teacher. for this, you need to have your arc checked by a special service with original software. they are looked after from there. If it is completely faulty, the error code will drop.
12.01.2022 11:47 # 3
KILIC
Generally, in the case of oxygen sensor failure, there is a rev fluctuation, and at the same time, the smell of cig gasoline comes from the exhaust. MAP sensor causes rpm fluctuation. Do you have a problem with your vehicle?
