peugeot 206 overheating problem
08.05.2020 15:06 # 1
semih
mrblar friends i am a new peugeot user. 2001 model 1.6 110 hp rolland garros vehicle and i have an atiker brand urine system tube but i can not use it. my other problem is the heat problem; I run the car without going 2 km over the road, the temperature rises over 90. When I go a little over the road, the temperature travels at 110 degrees. If I push it up, the temperature indicator rises above 100 degrees. The temperature varies between 90 and 100 at the moment.
08.05.2020 15:06 # 2
alaaddin
i have 2000 1.6 roland garros in me i had the same problem 95 i found blah then fan starts
08.05.2020 15:06 # 3
semih
thanks
08.05.2020 15:06 # 4
Muhammet CAKIR
If the temperature is 100, water will boil, you can take the engine, and if the water mixes, it will be bad, but the display may be broken.
08.05.2020 15:06 # 5
tugrulavci
[QUOTE = alaaddin]
I had the same problem in me. Since the radiator was not original, I changed the radiator.
08.05.2020 15:06 # 6
ali oncu
First try installing a low thermostat and take the problem seriously, otherwise it may cause much trouble.
