peugeot 206 overheating problem
08.05.2020 15:06 # 1
semih
mrb friends 2001 model 1.6 110 hp `` peugeot 206 rolland garros I have a temperature varies between 90 and 100 degrees is normal? sometimes even a little over 100?
08.05.2020 15:06 # 2
pendikpeugeotservis
SLM FRIEND SNN TOOL PREPARATION NORMAL MAXIMUM UP TO 105 NORMAL FAN FOR DOUBLE-STAGE FAN STORE OPERATING THE 105 GECTIM PROPLEM ACCORDING TO IT OK
08.05.2020 15:06 # 3
semih
thank you very much ... (PENDİKPEUGEOTSERVİS)
08.05.2020 15:06 # 4
semih
Sometimes it goes at 105 degrees in gasoline when my master pushes uphill.
08.05.2020 15:06 # 5
semih
Sometimes it passes at 105 degrees in gasoline, approaching the thick line under our country, when my master pushes uphill.
08.05.2020 15:06 # 6
I think there is a problem with the cooling system. I am convinced that it should not exceed 100. To be sure that the fan blows to a certain extent ...
08.05.2020 15:06 # 7
Yusuf Tekoglu
My vehicle 95 came, I went to the industry and I got it done. 200 TL parts. 150 TL labor. plus I made a bidet button. As soon as you die, your gasoline will burn the most jonta but the heat is very important for diesel users.
08.05.2020 15:06 # 8
Muhammet CAKIR
syun boiling degree is not 90 or do i know wrong? D
08.05.2020 15:06 # 9
Muhammet CAKIR
Also, you do not need to open the subject in two places.
Muhammet ÇAKIR 2011-02-15 18:42:14
08.05.2020 15:06 # 10
se®k@n
I think it should be 100 degrees for boiling. Gülme
You may be tempted, or your thermostat may be broken. I think you have them checked.
08.05.2020 15:06 # 11
semih
I changed the thermostat right now I'm riding in gasoline, my brother is playing between 90 degrees and 100 degrees, the temperature gauge sometimes passes 100 degrees when I push uphill. Thank you very much for your help.
08.05.2020 15:06 # 12
semih
I wonder how many of them should be normal, my friend has 2000 model roland garrros, my friend's vehicle is just below 95 degrees below 95 degrees. Does anyone know the norm, friends 2001 model 1.6 engine 110 hp rollland garros' s temperature how should be normal what is it? playing between degrees and 100 degrees, the temperature hand sometimes passes 100 degrees when I push uphill)
Best regards
seMiH 2011-02-17 02:49:43
08.05.2020 15:06 # 13
xdesign
The other vehicles grip at 90 (stock temperature), while Peugeot and Citroen grip at 95. My vehicle sometimes confuses 100. These happen in heavy traffic. Sure, of course. When you find a gap, go up to 3500 rpm in 2nd gear, then throw it to 3, protect your cycle, it will return to normal.
08.05.2020 15:06 # 14
Onur
I changed the thermostat, the 80-90 navigation in the old thermostat is approaching 110 when the 90-100 ramp is going out after the new thermostat or when I force it.
08.05.2020 15:06 # 15
Muhammet CAKIR
I know 90 boiling and 100 evaporation Gülme The reason why the vehicle goes up to 110 degrees: The dating has a closed circuit engine and it works at very high temperatures, but when I saw 95 in it, the gasket was burned, this issue confused me very much, but these temperatures must remain at 90 degrees, no more than 90 millimeters. detrimental
08.05.2020 15:06 # 16
gencoto izmir
slm my friend, your problem is caused by radiator, in other cases, if you do not open the thermostat, the fan will not turn on and the gasket will burn down to the engine, show it to an experienced friend as soon as possible
08.05.2020 15:06 # 17
semih
My friend has 2000 model 206 rolland garros and the temperature hand forces 90 degrees very little.
08.05.2020 15:06 # 18
Onur
thermostat is switching on, fan is on, there is no problem, but a light water decreases from 2 to 2 months.
08.05.2020 15:06 # 19
gencoto izmir
friends pejos usually have a fan switching rate of 95 after that if the problem goes up, show it to a specialist immediately
08.05.2020 15:06 # 20
semih
thanks guys for sharing your info ...
Page : / 2
