PEUGEOT 206 OIL INDICATOR PROBLEM
08.05.2020 19:06 # 1
muhammet.ozdiyar
CAR 2005 MODEL PEUGEOT 206 X-DESING
When the car dashboard was opened when I started my car, 6 boxes normally would show the oil level and then showed the mileage of the vehicle. But when I run it today, only 6 lines are blinking in the Oil indicator. What is the problem?
08.05.2020 19:06 # 2
Efe-Pojo
check the oil of the car, if it is normal, the sensor has failed, if not, add oil immediately.
08.05.2020 19:06 # 3
muhammet.ozdiyar
I changed her oil 1 month ago and when she had a problem, I took her to the place where I changed the oil, said the oil level and the oil is normal.
08.05.2020 19:06 # 4
Efe-Pojo
I changed the oil [QUOTE = muhammet.ozdiyar] 1 month ago and when it was a problem, I took it to the place where I changed it and made it look oil level and the oil said normal [/ QUOTE]
then the sender failed.
08.05.2020 19:06 # 5
muhammet.ozdiyar
Well, is there any urgency to change this immediately?
08.05.2020 19:06 # 6
monalos
I have been using it for 3 months like this: D went to the service, he did the same if he changed, he did not change the bde.
08.05.2020 19:06 # 7
muhammet.ozdiyar
There is no peugeot service in my city, the nearest service is 300 km away, so I get help from you guys here ... I know that in my car, the oil is occasionally maximum, sometimes I check after everything, everything is normal after a while but this time only when the line flashes I wondered if I ordered the sender, I will let you know if it gets better.
08.05.2020 19:06 # 8
monalos
okay I am thinking of changing it, I have no harm in my hand.
08.05.2020 19:06 # 9
Efe-Pojo
[QUOTE = muhammet.ozdiyar] Well, is there any urgency to change this right now?
[/ QUOTE] It is okay to use it like this, but you can not understand if it really decreases fat if this happens.
08.05.2020 19:06 # 10
monalos
can not be understood from the bar?
08.05.2020 19:06 # 11
muhammet.ozdiyar
how is it understood, if the oil does not diminish or not ... he looked at the bar where I put oil, and he said normal
08.05.2020 19:06 # 12
muhammet.ozdiyar
[/ QUOTE] It is okay to use it like this, but you can not understand if it really decreases fat. If such a situation occurs. [/ QUOTE]
so how do we know
