Peugeot 206 Oil dripped !!
08.05.2020 20:24 # 1
hasayduman
Hello,
Peugeot 206 2005 model gasoline + LPG car I realized on the weekend that 5-10 drops of oil flowed on the rust rust, when I applied my hand to the black ground there, I got oil like engine oil,
Does anyone know about this?
Sygun
08.05.2020 20:24 # 2
pusutr
I wonder if you stepped on an oil spill on the road, it seems that your heel got oil on it. Whether it drips there, water drips ..
08.05.2020 20:24 # 3
KILIC
I think we are antifreeze. may have dripped from the heater core.
08.05.2020 20:24 # 4
hasayduman
[QUOTE = pusutr] I wonder if you stepped on an oil spill on the road, it looks like oil got on your heels. Whether it drips there, water drips ..
I thought like you, at first, when I drove my hand towards the radiator pipe to stop the water, oil came to my hand, if there was water, it would dry as a stain on the mat.
08.05.2020 20:24 # 5
hasayduman
[QUOTE = KILIÇ] I think we are antifreeze. may have dripped from the heater core. [/ QUOTE]
I think we can be antifreeze, the radiator water is a bit diminished,
08.05.2020 20:24 # 6
hasayduman
There was radiator removal and tire replacement in the forum, I couldn't find it
08.05.2020 20:24 # 7
boruc
Antifreeze water dripping from 90% calorie core
A situation frequently encountered in these vehicles
08.05.2020 20:24 # 8
doganatak
Take a look at these topics maybe it helps
doganatak 2017-06-07 10:32:05
08.05.2020 20:24 # 9
hasayduman
[QUOTE = doganatak] Have a look at these issues maybe help
Tşkler,
It worked well for me, the only problem is where to find the gaskets, I will stop by the eagle industry and look at it, I am thinking of trying it over the weekend.
08.05.2020 20:24 # 10
onlycihan
I think that before the oring change, complete the missing connection bolts there. I do not know what is to throw a single bolt instead of 3 bolts.
08.05.2020 20:24 # 11
hasayduman
So how do you measure bolts, do you have a measure, etc.?
08.05.2020 20:24 # 12
[QUOTE = hasayduman] Well, what kind of bolt is there, measure, etc. Do you have a measurement? [/ QUOTE] measurement usually, nobody knows, teacher, you need to remove the screw and nut and get something suitable for it.
08.05.2020 20:24 # 13
related topics
08.05.2020 20:24 # 14
hasayduman
[QUOTE = sonerkyl] [QUOTE = hasayduman] Well, what kind of bolt is there, measure, etc. Do you know? [/ QUOTE]
I hope I solve it.
08.05.2020 20:24 # 15
Popomundo
[QUOTE = hasayduman] Well, what kind of bolt is there, measure, etc. Do you have a bolt? 4 / bolt that holds 8 keys, so be sure to change the hand when the car is cold.
08.05.2020 20:24 # 16
hasayduman
[QUOTE = Popomundo] [QUOTE = hasayduman] Well, what kind of bolts do you measure, measure, etc.? / quote]
Thank you very much.
08.05.2020 20:24 # 17
Popomundo
They fill 3 liters of antifreeze after the car is the weakest, it explodes from there, whatever the purpose is, whether the car does not freeze or not, 1.5 liters of antifreeze for the normal vehicle.
08.05.2020 20:24 # 18
Aleynaboyner
Antifreeze coming from heating honeycombs made 250 pounds in maslak auto industry, but it came to the press twice.
08.05.2020 20:24 # 19
Popomundo
[QUOTE = Aleynaboyner] Antifreeze from heating honeycomb made 250 pounds in maslak auto industry, but it came to the press twice, at last they changed the honey, I had a lot of problems like this. there is only water [/ QUOTE] You would have to replace the radiator with the original one and get rid of it at once. Otherwise there is no gasket. Wink
08.05.2020 20:24 # 20
Aleynaboyner
Short correct red color antifreeze:))))
Page : / 2
