Peugeot 206 not working
08.05.2020 21:08 # 1
Hatemi
Hello dear forum members, I said that my vehicle peugeot 206 2008 model is frozen or not, but I guess.
We tried with a jumper cable, it sounds like the battery is running out, it doesn't work every time but it doesn't work. Headlight lights turn on and off after starting
I said let me ask you.
Khatami 2019-01-21 15:07:27
08.05.2020 21:08 # 2
If the headlights are turned on spontaneously during the start, there is a problem in the electrical system. it's probably a short circuit. Is there an electrical system that you added to the vehicle later. sound system - xenon etc. like. Of course, do not force the vehicle too much and I recommend you to have a good master with the hammer.
08.05.2020 21:08 # 3
Hatemi
When xenon headlight is attached, the starter is pressed, the battery runs out almost 10 times I pressed the battery does not run out, while the headlight lights are flashing
08.05.2020 21:08 # 4
Remove the xenon definitely, hodja. vehicle diesel i think the fuel light is on
08.05.2020 21:08 # 5
Hatemi
On fire Khatami 2019-01-21 17:21:47
08.05.2020 21:08 # 6
My teacher, then take 5 liters of fuel, and try to start a starter. it may have had air.
08.05.2020 21:08 # 7
Hatemi
there is fuel in it thanks
08.05.2020 21:08 # 8
onurrr41
Could there be a problem with the starter motor? Would you try to start the starter while a friend touches the starter with a hammer?
08.05.2020 21:08 # 9
Hatemi
To be tested
08.05.2020 21:08 # 10
Designbyonurkaya
[QUOTE = Hatemi] Hello dear forum members, my car peugeot 206 2008 model I wonder if diesel is frozen but I guess not.
Open the fuse board of the engine, check the 8-pin fuse problem is 80 percent
