peugeot 206 misfire and engine warning light
11.04.2022 17:24 # 1
Oyazici
Hello everyone
My vehicle is Peugeot 206 1.4 feline 2006 semi-auto.
My vehicle sometimes stutters, especially when idling, it seems to stop and then turns on the yellow warning light. When it was connected to the computer, it gave the error P0204.
This warning light usually turns on when the fuel in the tank is low. When I fill the tank and use it for a while, the light may turn off.
In general, I can say that the traction of the vehicle is low
I used injector cleaner because there was an injector error, but the same problem continues.
I would be very grateful if you could give some helpful advice. I can also get your expert advice in Istanbul who understands this tool
14.04.2022 08:55 # 2
Hello, I think there is no LPG in the car. Also have the spark plugs and fuel injector sockets checked. and replace the fuel filter. If the problem occurs when the fuel is low, the fuel pump may be in trouble. Lots of people recommend this place.
14.04.2022 10:22 # 3
Oyazici
Soner, thank you very much for your reply. I'll take a look at what you said
