Peugeot 206 License plate lights replacement
08.05.2020 14:02 # 1
hasimayaz
http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=45
08.05.2020 14:02 # 2
lkr_yldz
if these issues were removed, it seemed before but now it is not visible how do we do it?
08.05.2020 14:02 # 3
GokhaN
[QUOTE = lkr_yldz] if these issues were removed, it seemed before but now it is not visible how do we change these license plate lamps [/ QUOTE]
I fixed it. I made some new settings while moving the server. I have not applied to some pages.
08.05.2020 14:02 # 4
Are their bulbs the same standard bottomless bulb as the park?
08.05.2020 14:02 # 5
[QUOTE = Berkay] Are their bulbs the same standard bottomless bulb as the park? [/ QUOTE]
Yes, the no-light bulb used in many vehicles.
If you like, you can wear the LEDs instead of them, with large, flat painless bulbs.
For example, these are like ... But there are different colors ...
ModaCar SMD Mavi 4 Ledli Park Ampülü  85a02853
08.05.2020 14:02 # 6
metin
I highly recommend different angle leds. I used right angle. The license plate lamp illuminated sideways as my senses stared diagonally, but the middle part remained a little light, so I am thinking of taking out the light emitters.
08.05.2020 14:02 # 7
[QUOTE = text]
Wait a minute, I think there is a misunderstanding.
Metin brothers leds are very various medicine. Some of them are narrow and some are wide. If you look at the leds that I sample, they emit 180 degrees wide pain. Looking straight means that the direction of the leds is not looking sideways. But it does not have any problem on the light sides. Because there is no reflective feature in the mirror of the lamp. Whatever comes out of the light bulb will look ...
I do not recommend the hiccup with a narrow luminous LED on it.
If it is necessary to sample the event
I do not take those who like it ... These leds give a light. When you look from the side, you will not see ...
There are LED bulbs in the style I show below. You can also use them. However, the length of the original is sometimes slightly lighter than W5W, so it may not fit. I have it, I hit the cover of my license plate lamp so I couldn't wear it ...
08.05.2020 14:02 # 8
metin
brother, I have the last Philips ones you showed me. I think I will illuminate the plate completely. There are only LEDs on my license plate as in the first picture you put. Since these slots stand sideways, they illuminate to the right on the right and to the left on the left, and the light in the middle is slightly less than the sides in the shape of a triangle. There is no problem in terms of length. text 2011-07-13 15:43:17
08.05.2020 14:02 # 9
lkr_yldz
THANKS FOR YOUR ATTENTION TO GÖKHAN FRIEND. AND THANKS FOR YOUR ALL FRIENDS 'EXPLANATIONS
